01-01-2010, 01:50 AM | #1 |
Shock mount question
ok after putting my ece drop on with rear shock relocators, on one of the mounting holes on the shock crossmember, where the rivets use to be, is cracked. would be hard to see in a pic. is this ok? or do i need to weld it up? any one make a aftermarket one?
01-01-2010, 09:58 PM | #2 |
Never Ending Projects
Re: Shock mount question
You should weld up the crack so it won't get bigger and cause more problems. It's only metal and a welder is your friend.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-01-2010, 10:07 PM | #3 |
anybody know of an aftermarket one? can you buy just the one from art without buying everything?
01-01-2010, 11:53 PM | #4 |
Fix the crack as that area of the suspension gets a lot of force applied. If you don't fix it now, you will just have to later...such is the cycle.
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
