Old 01-01-2010, 02:25 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Remote keyless entry install - are the locks positive or negative?
I haven't installed an alarm, remote start or remote keyless entry since the 90's, and don't remember how to determine positive locking from negative locking.
Anyone know how to check, or know what the 85's locks would be?
Thanks!!!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-01-2010, 04:33 PM   #2
463
463's Avatar
Re: Remote keyless entry install - are the locks positive or negative?
this is the 87 but should be the same.http://www.bulldogsecurity.com/ CHEVROLET
MODEL YEAR(S)
FULL SIZE PICKUP 1987 -
KEY T-HARNESS IMMOBILIZER
N/A N/A N/A
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED (+) IGNITION SWITCH HARNESS
STARTER YELLOW (+) or PURPLE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 PINK (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) BROWN (+) @ HEADLIGHT SWITCH or FUSE PANEL
POWER LOCK LIGHT BLUE (TYPE A) IN DRIVERS DOOR HARNESS
POWER UNLOCK BLACK/WHITE (TYPE A) IN DRIVERS DOOR HARNESS
LOCK MOTOR WIRE GRAY (+) IN DRIVERS DOOR HARNESS
DOOR TRIGGER WHITE (-) @ UNDER DASH AREA
DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires #775 Relay
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN BLACK (-) @ STEERING COLUMN HARNESS
TACH PURPLE/WHITE @ DISTRIBUTOR or ECM, See NOTE *1
WAIT TO START LIGHT See NOTE *2
BRAKE WHITE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFT N/A
NOTES
NOTE *1 the ECM is located behind the Glove Box, it is a SILVER BOX with 2 Plugs.
NOTE *2 when hooking up a REMOTE STARTER on a DIESEL, if the WAIT to START wire from the Remote Starter does not wait until the Light on the dash turn out before cranking, you will need to program in the 5,10 or 15 Second WAIT to START TIMMER in the Installation Manual. On some vehicles the Wait to Start Light on the dash is not a true (+)Positive or (-)Negative and the wire from the Remote Starter will not owrk. When this Wait to Start Timmer is programmed, disconnect and tape up the Wait to Start wire from the Remote Starter that is tied into the Wait to Start Light on the dash.
LINK 1 LINK TEXT 1 LINK 2 LINK TEXT 2
EXTRA INFORMATION
Trueman
463 is offline   Reply With Quote
Old 01-01-2010, 10:53 PM   #3
glock35ipsc
Beauty, thanks!!!! Any idea what "TYPE A" refers to? It rings a bell, but can't quite remember.
I use to have access to that type of info, but back then we had to call an automated machine, and it would automatically fax the info to you after inputting all the info (year, make, model, etc).
Bob
Old 01-01-2010, 11:13 PM   #4
463
463's Avatar
cant remember for sure what TYPE A means. i will have to dig back in my gray matter and get back to you Bob.
Trueman
Old 01-02-2010, 03:40 PM   #5
glock35ipsc
Figured it out. They are positive locks.
At the master switch (drivers door), if the lock and unlock wires are ground at rest, and 12v when activated, they are positive.
Got is installed and I'm loving it. No more scratched door paint!
Bob
Old 01-02-2010, 04:19 PM   #6
463
463's Avatar
good stuff. you beat me to it.
Trueman
