Old 01-02-2010, 03:49 AM   #1
jdaley
Temp Gauge working?
I have just done an 800km trip with the new toy.
Aproblem has arisen, the temp gauge does not appear to be working and I have blown the hesd gasket.
How do I check the temp. gauge?
I have a new gasket set arriving are there any further problems I may encounter from thsi one. I dont expect a warped headis that a fair assumption?
John Daley
Melbourne, Australia
1946 Chev Ute
1977 Chev Tray
Road racing sidecars
jdaley is offline   Reply With Quote
Old 01-02-2010, 07:47 AM   #2
SliverBlack86
Re: Temp Gauge working?
Originally Posted by jdaley View Post
Aproblem has arisen, the temp gauge does not appear to be working ...
If you have no sensor and, or wiring problems use an infrared temp gun aimed at the area around the sensor and compare it with the gauge. because the gun is sensing metal temp while the sensor is sensing the coolant temp the two reading will not be the same, but should give you an idea of the gauge accuracy. Remember this is quite an old gauge expect its accuracy to have deteriorated.
SliverBlack86 is offline   Reply With Quote
Old 01-02-2010, 07:18 PM   #3
jdaley
Can I expect any other damage as a result of the overheating?
Some engines just cannot take a single overheat, such as aluminium heads.
John Daley
1946 Chev Ute
1977 Chev Tray
Old 01-02-2010, 11:42 PM   #4
SliverBlack86
How long did you run the engine hot till it blew the gasket? Or, did it overheat rapidly and blow immediately?
Which cylinder(s) blew 3,4, 5, or 6?
Most likely bearing failure if the proper precautions were not taken to flush any coolant in the oil.
Old 01-03-2010, 11:17 AM   #5
68 TT
Still plays with trucks
68 TT's Avatar
If you overheated it enough that it blew a head gasket you really need to take it apart and have a machine shop check for flatness on the deck and heads as well as inspect for cracks.
You also probably overheated the rings and caused them to lose a little tension so it will probably smoke more now if you don't replace them.
Take this as an opportunity to freshen up the engine and re-seal the whole thing. You are going to have it 75% of the way disassembled so why not finish the job. Rings and bearings are cheap.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-03-2010, 11:24 AM   #6
ironroad9c1
Master Hater
Couldn't agree more... you will be pleased with the fresh engine.
ironroad9c1 is offline   Reply With Quote
Old 01-03-2010, 02:18 PM   #7
73step
73step's Avatar
if your going to pull the heads your better off pulling the whole motor and freshening it up. Here is a cheap way to go over everything http://www.summitracing.com/parts/FEM-MK630C-000/
73step is offline   Reply With Quote
Old 01-03-2010, 05:30 PM   #8
jdaley
THanks, but summit dont seem to have kits for 6 cyl 292's.
John Daley
1946 Chev Ute
1977 Chev Tray
Old 01-03-2010, 10:15 PM   #9
73step
73step's Avatar
sorry bud i didnt think as to what was under your hood
