Old 01-03-2010, 12:55 AM   #1
shade67
Question cab mounts too tall?
I rebuilt my cab with new rockers and floors. I put in urethane bushings and now I'm in the process of lineing up the doors and fenders. BUT, the radiator support is too low when bolted to frame with the correct 67-68 radiator support mount set. If I mount it higher then the grille assy. is too high for the bumper to bolt on. Where did I go wrong- I used 1/2t bushing set.
Scott
66 chevy short step 327 4speed
67 chevy Short Fleet tpi 350 700r4
72 chevy K10 swb
01 GMC Sierra
01 Pontiac Bonneville
shade67 is offline   Reply With Quote
Old 01-03-2010, 03:19 AM   #2
beautimus
beautimus's Avatar
Re: cab mounts too tall?
did you change the core support mounts ?
over time all the mounts compress at the same rate, so if you didn't change the rubber mounts under the core support you can expect to be off 1/2 to 3/4 of an inch. also if you used polyurethane mount cushions you can expect the problem to be even worse. another note is after you get the cab and core support lined up you may have to put shims under the bed to keep it from looking to low. good luck !!
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 01-03-2010, 03:30 AM   #3
67chevy2wd
67chevy2wd's Avatar
Do you have 4x4 cab mounts or 2wd cab mounts? The 4x4 cab mounts sit taller.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 01-03-2010, 10:13 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
actually, I think the only differance between the 1/2 ton 2 wheel drive bushings, and the part number for all other trucks, is in the rear cab bushings. I think the front ones are the same.
Old 01-03-2010, 10:25 AM   #5
suville
suville's Avatar
60-68 core support mounting hardware is not the same as 69-72, you should be able to shim with large diameter washers the amount necessary to achieve the alignment. If you can do pics it might help to address your fitment issues.
suville is offline   Reply With Quote
