driving is in my blood
Simple question
I have a component set of 6.5"s and 1" tweeters up front in my truck. Does the component set require 2 channels [one channel to drive each pair] from an amp or 4 [one for each speaker]?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
3/4 Ton Rodder
Re: Simple question
From what I've heard its 1 channel per pair.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
>130dB Moderator
Re: Simple question
1 channel/pair passive. 2 channel/pair active.
Passive = using the little x-over box that came with the speakers Active = throwing that little box in the trash and using a signal processor to tell the speakers what to do. I'm going with you're on passive, so it's one channel per mid/tweeter, so a 2ch amp is what you're looking for.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
Re: Simple question
AceX your correct,Im using the crossover box that came with the speakers. So if the setup is rated 200max/100 rms then I need one channel at 100 per side right? sounds simple enough. Thanks for the info guys.
Re: Simple question
you want a 2 channel for a set of compnets if you have rear speakers also 4 total and your tweeters you want to use a 4channel but you can also run the componets on a 4 channel and use the other 2 channels for a sub if you wanted some bass
you want a 2 channel that is not strickly a bass amp which most arnt just for bass there will be a cross over switch on the amp that has settings for hp (high pass) LP ( low pass) and FULL you want the amp set to full low pass=bass only high pass=treble only full=treble mid and bass |
