01-05-2010, 09:56 PM | #1 |
ash tray wont close...
Its not a huge thing but how many people have this problem? I tried uploading pics but my computers screwed up. The ash tray opens up to the right spot but when I close it it hangs open about an inch and a half... Does anyone know how to fix this? Thanks
"I'll keep my guns, money, and freedom. You can keep the "change" |
01-05-2010, 11:07 PM | #2 |
Robert Olson Transport
Re: ash tray wont close...
i would pop it out and see if something is hanging it up..
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
01-05-2010, 11:10 PM | #3 |
It'll close all the way but then it falls back open to about an inch ir so open and stays there.
01-05-2010, 11:33 PM | #4 |
Project Optimus Prime
i had this s ame problem on my truck so i took it out and it was missing the 2 springs that hold it closed, there is 1 spring on each side and urs is most likely missing them or there broken. i have a burb that i take parts from and of course tha 1 on there was in perfect shape and closed all tha way, and then presto change-o!!!!!! now mine is perfect!! LMAO!
84 SWB work in progress 89 burb 1500 (parts pig) LOL 08 ford focus (I know, I know) Wifes car "I said it b4 and i'll say it agian wiring is my worst enemy":devil: |
01-05-2010, 11:35 PM | #5 |
im trying to remember if it has springs on it to keep it closed.. prolly have to disassemble the thing to see
01-05-2010, 11:39 PM | #6 |
That's most likely what I need.. Where do the springs hook on? Does anyone have any pics?
01-06-2010, 12:02 AM | #7 |
GM Addicted
take the ash try out and where the pivot point is the should be a spring on each side, you will see the two holes on each side for the springs, run down to your local pick a part and snag you the two you need thats what i did to fix mine, good luck
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
01-06-2010, 12:08 AM | #8 |
Ok thanks. Ill check it out tomorrow. Ill try to take a pic or two of my ash tray. I don't smoke so I sovered the opening with an aluminum plate and I put a water temp guage there till I get the one in my cluster working, and there's a switch for my fog lights. When I bought the truck it had an ash tray and lighter so I know the guage isn't just weighing it down. Ill look for those spring holes tomorow thanks a lot guys
01-06-2010, 12:10 AM | #9 |
GM Addicted
alrite and mount your gauge under the ash tray with the screw hole for it, look at my build thread and look where mine are mounted its the link by my sig..
01-06-2010, 12:17 AM | #10 |
Before I move the guage anywhere ill just get rid of it. Its just a cheap-o from auto zone until I figure out how to fix the one in my dash. When I get rid of the guage I'm just goung to make a new plate and fill it with switches for all my goodies.. Fog lights, strobes that I mounted in my running lights,and so on
01-06-2010, 10:29 AM | #11 |
Master Hater
I looked at ashtrays in the JY cause mine was doing the same thing and they look like the Ashtray housing is riveted at the pivot points
01-06-2010, 11:06 AM | #12 | |
Yes - it has springs and yes it is riveted at the pivot points (...at least mine was).
I couldn't find springs for a 73 - 87 but could find springs for an 88 and up. I ordered those and installed them; they seemed to work fine. K Quote:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-06-2010 at 11:07 AM. |
01-06-2010, 08:17 PM | #13 |
Hey thanlks keith. I looked at my ash tray and I have no springs.. So springs for an 88 truck will work? If I can't buy any at the parts store I could go to a junkyard but its about a half hour away and at 7 mpg its alnost not worth it till I need to get more stuff from there lol
01-06-2010, 08:51 PM | #14 |
Badass
so your putting a gauge in there? i was thinking to put a tach in that make a flate plate and then put a hole in it and put it there as like a sleeper look
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
01-06-2010, 08:57 PM | #15 |
I was planning on putting a blanking plate were the ashtray was and switches there for a brake/tag light kill switch and underlighting kit switch
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 Last edited by Chlsnk; 01-06-2010 at 08:57 PM. |
01-06-2010, 08:53 PM | #16 |
GM Addicted
i didnt know they sold the little springs i actually had another ash tray laying around that i took mine out of..
01-06-2010, 09:01 PM | #17 |
I'm not going to, the guage is alreddy there but eventually ill ditch the cheapo temp guage and hook up the little tach I have
01-06-2010, 09:10 PM | #18 |
Master Hater
Well after some examining Turns out I had one spring in there, it was just unhooked, clipped it in and presto changeo, its fixed, Also had to tweek the lower part of the outside cause it was bent and rubbing on the bottom. but works good now and I seen where I can remove the assy..lol didn't catch that the other day.
01-06-2010, 09:18 PM | #19 |
[IMG]get-attachment.aspx?uid=1.24333232&folder=NewMail&partId=2[/IMG]
there she is.... im outting a little sunpro tach in there soon. anyone know where to start when trying to find ou twhy a stock temp guage dont work? http://webmail.aol.com/30272-111/aol...wMail&partId=2
"I'll keep my guns, money, and freedom. You can keep the "change" Last edited by bitchin85; 01-06-2010 at 09:22 PM. |
01-06-2010, 10:43 PM | #20 |
This is off topic but when i open my glove compartment it will fall to the floor. Anybody have this problem and any solutions? i think i need to replace 2 missing screws at the bottom of the base
Thanks |
01-07-2010, 08:20 AM | #21 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-07-2010 at 08:23 AM. |
02-11-2010, 11:21 PM | #22 |
Squarebody Aficionado
I cant find out how to take out my ashtray i had the dash taken apart the other day and took out the 4 screws and it was loose but couldnt find out how to get it out. I have both springs but have no way to figure this out without getting super fustrated. please help me out. I find it funny on how something so small can end up driving us car/truvck guys crazy
02-12-2010, 10:56 AM | #23 |
anyone?
02-12-2010, 11:34 AM | #24 |
Sorry - I saw your question and got distracted -
I had the IP top pad off of my truck and the ductwork out when I was doing the ashtray stuff. That makes it quite a bit easier, as there is a big access hole directly above it. Taking the glovebox out also gives you another opportunity to get your hand in there. Bottom line - it should come out the ashtray opening in the dash but you do have to roll it around a bit and play with it (like those bar room puzzles). Maybe sideways or at an angle. Keep trying and I'm sure you'll find a way. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-12-2010 at 11:35 AM. |
02-12-2010, 11:35 AM | #25 |
when you mean loose you were able to move it around but the air conditioner vent tube or whatever part of the HVAC stuff is back there on on the bottom wouldnt let you slide it out underneath? just pop the glovebox and you should be able to back it out that way
