![]() Join Date: Jun 2003
Who can tell me the difference in overall width (WMS to WMS) between an 8 lug Dana 44 front axle (Big Spindle, Disk Brake) and an HO72 rear axle (8 lug 9/16 studs, leaf spring type)??
I'll bet a few of my fellow 4x4 enthusiasts know this info as well as their wife's birth date? LOL!! (maybe better?) Thanks, 72longbed Last edited by 72longbed; 01-05-2010 at 10:03 PM. |
Re: Axle Width Question?
should be 3 inches
Yellow70,
Thanks, where do you get your numbers to know that there is a 3 inch difference? I can't seem to find any data on the measurements I'm looking for. Thanks, 72longbed |
All the straight axle chevy trucks from 67-91 have a 3" difference between the front and rear axles. You're talking about total track width from lug surface to lug surface, correct?
I'm also assuming that an HO72 is the same width as the 12 bolt, 14 bolt, and 10 bolt. I could be wrong, i've never owned a truck with an HO72. But the 12b, 14b, and 10b are all the same.
Ok .... so what is that width of the front or rear or both? Is it 65", is it 68"?
I'm looking for a printed guide to the Dana HD 44 1971/72 that specs the WMS (wheel mounting surface) width. It would also be good to find a similar resource for the HO72 and HO52. I have an HO72 under my truck but I don't know what it came out of. It's not stock to my truck. I guess I could try to get an accurate measurement from under the truck once we get out of this deep freeze we're having here. I want to make the rear axle wider with spacers/adapters so it is the same width as the Dana 44, and need to know what thickness I'll need in the rear. Thanks, 72longbed |
Fronts are usually 69" or so, rears are aboot 65". Get a rear from a van, same width as the front.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
Thanks b454rat ... but I won't be changing that rear. I'm one of the old school'er types who knows that the HO72 is about a bullet proof as you can get from a factory rear. With the locker in there, and the matching ratio to the HD Dana 44 up front ... I'm happy. I will make it a bit wider to fill out those wheel wells out back.
I'll do some more research to see if I can find a list of GM axle widths somewhere? 72 Last edited by 72longbed; 01-08-2010 at 07:35 PM. |
http://77cj.littlekeylime.com/Dana44.htm
Its somewhere in here, can't remember where. But most GM axles are either 67" for 1/2 or 69" for 3/4 and 1 ton.
You could use wheel spacers on the rear to make up the difference, i've known a few people who have used 1 1/2 spacers on each rear wheel and it looked perfect. The only problem is it will put additional pressure on the outer wheel bearings.
