01-06-2010, 02:11 AM | #1 |
Dropmember and body drop questions
I have decided to go with a dm on my 68. my question is if i use 73-87 lca and my 68 uca, which nate said i can do, do i just put a 68 ball joint in the 73-87 lca? this set up will be just until i afford his tubular ones. and how are tall routing your brake, fuel, and trans lines? pics if you got em. i also what do i do about the the steering shaft? i seen a few home made brackets, but does the kit come come with one? also how would i go about lowering the body 1"?
01-06-2010, 01:57 PM | #2 |
Re: Dropmember and body drop questions
Use whichever year lower balljoint your spindles are for.
Doug Looking for a 67-72 short bed driver..... |
01-06-2010, 11:36 PM | #3 |
67-72 parts collector,…
This might get a better response in the "suspension section".
I'll see if I can get it moved,... if you don't mind. |
01-06-2010, 11:52 PM | #4 | |
01-07-2010, 08:45 AM | #5 | |
http://porterbuiltstreetrods.com/site/ |
