01-06-2010, 04:31 PM | #1 |
door panels
can you use 72 door panels on 67-71 doors? any help would be awsome. thanks mike
67 short bed stepside tach tilt buddy buckets bagged sittin on 20s and 4w disc brakes (not quite finnished) |
01-06-2010, 04:35 PM | #2 |
Moderator
Re: door panels
Yup, just need 72 window regulators to compensate for the thickness of the panel. You may need to drill several holes in the door for the plastic clips that hold the panel to the door.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-06-2010, 04:41 PM | #3 |
Re: door panels
Im not saying this is wrong but i put 72 door panels on my 67 and used my 67 regulators. It was i tight fit but they worked. I also had to put nuts in the door mount the arm rest. I think i just had to make the holes where the upper strip was bigger so i could fit clips in.
01-06-2010, 07:07 PM | #4 |
An American Soldier
Re: door panels
Yep,
I put 72's onmy old 69. I did not change regulators. It will work, but it's tight. Not too easy to get the handles back off, but it certainly is doable.
Dan dan.brue@us.army.mil |
01-07-2010, 07:27 PM | #5 |
406 Powered
Re: door panels
They work but there tight. Thats what i did. Not a great pic but you get the idea.
70 GMC 68 c10 2002 silverado 72 4x4 |
01-07-2010, 11:50 PM | #6 |
motor exploder
Re: door panels
here's mine - not a really good pic, but you can see enough.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
01-07-2010, 03:32 PM | #7 |
Moderator
Re: door panels
They won't work if you are planning on using the 72 woodgrain panels. Well, they probably will if you beat the handle on with a mallet and don't plan on removing it again
01-07-2010, 04:03 PM | #8 |
motor exploder
Re: door panels
I also have '72 panels on my '69 doors - my grandfather did them when he restored the truck back in 1990-91. I have tried a few times to get the window crank handles off and I can't...
01-08-2010, 02:02 AM | #9 |
Re: door panels
the regs are cheap enough off here that theres really no reason to work harder instead of smarter.... i like the 72 panels way better than the early years.....
