75 chevy wiring issue
So i finally got my truck back together after installing a new exhaust, an MSD ignition and new intake. Anyway while running the msd wires into the cab i accidently ran a screw through the power wire for the msd box. So not knowing, i hooked the cable to the battery. Now the heater fan does not come on and the gas tank switch doesnt switch tanks. I checked all the fuses i could find and obviously fixed the wire but cant get it working. Does anybody know which wire i may have burnt out or what i should check?
Happy to be here
![]() Join Date: Mar 2000
Re: 75 chevy wiring issue
Anyone?
Looking at my 77 wiring diagrams, the only thing I could think of is a splice point. I do remember when I took my wiring harness out of my truck there was a nasty splice that had 6 wires with a cheesy crimp that look ratty. It was a group of red think wires. Did you splice into a pink wire with black stripe? If I remember correctly that was the power wire color for mine.
1977 Chevy Cheyenne 2wd SWB Last edited by keith61760; 01-07-2010 at 11:25 PM. |
Thanks for replying. No i didnt splice into any wires for the msd box. It is ran directly to the battery. Im thinking im going to go down the the wrecking yard and grab a relay for the fan and look through what wires i can on a truck without an engine. What would really help is a wiring diagram of the truck. Would you be able to post your 77 diagram?
#5 | |
1977 Chevy Cheyenne 2wd SWB |
#6 | |
Thanks! |
The blower motor 12 volts comes from the ignition switch through a 20-amp fuse.
The fuse is located at the top right corner of the fuse box. First thing to do is check and see if you have 12 volts at both ends of that fuse with the ignition switch turned to the run position. Yes it would be nice to have a good one page wring diagram on line.
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
#8 | |
Here's some diagrams which may help. If you ran the msd wire direct to batt your problems are unrelated to your short to ground troubleshoot each circuit starting at the fuse as mentioned by ron350.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
