Best All Around Motor?
When every thing is considered,PRICE,ease of installation,fuel economy,power,etc. Does it always come back to the SB350?I know the LS motors are great,but they cost a lot more,and the average guy still might find it hard to do the swap!Maybe the SB400?What do you think?
![]() Join Date: Jul 2006
Re: Best All Around Motor?
Yes, late model roller block, vortec heads, streetable cam. Very serviceable and can be built to your preference pretty affordably.
That's what I was thinking.I wonder how much more a 383 is,everything else being equal?
Champagne Taste on Beer Budget
Depends if you want Performance over Economy really.
And what you expect out of your engine. If you want performance then yes the price will go up accordingly. A good crate engine in the 260-290hp range would be a good choice for MPG use. Just depends what you want out of your powerplant. Good luck.
Coming Soon: Project 1970 Country Truck |
i like the 307. it does every thing the 350 does but cost.
I like the 400 small block. It uses no more space and weighs no more but makes a lot more torque. They are compareable cost to rebuild and most all the brackets are interchangeable,
#7 | |
I agree 100%,,,I went with a small block 400....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
There are a lot of 350s around here, one 400 SB and two 402 BBs - and they all run well. But, by far the best running are a 327 that came in a 69 C20 and a 327 that came in a 67 Corvette.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
383 or 396 stroked.
Get the cubic inches and the added cooling without sacrificing cracking a block. I am sure there are more to add to this!!!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
![]() Join Date: Jan 2008
"Small Block 400" My .02
Chevy Lover Till The End.
x2
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
Andy
I love my 406.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi 1969 CST/10 383|Aisin AR5 5 speed 1972 K5 350|Turbo 350 4x4 2005 Duramax 2500HD 4x4 |
If you are talking "old school SB", the 327 has my vote also. IMHO, that short stroke /big bore SB did give up a little tork as compaired to a 350....but that lill bioch would REV & do it fast! The thing that we all understand, & that there is no replacement for displacement. However, that is not the complete game......make ALL the pcs match(cam/gearing/ect), & that lill short stroke mouse will kick some azz, even in a 3800 lb truck
http://community.webshots.com/user/hotrodhorn Last edited by 69 longhorn; 02-08-2010 at 03:04 AM. Reason: spelling |
![]() Join Date: Aug 2004
with proper prep ( as with any engine/trans swap) the LS is your best bet. There are parts readily available for this swap into just about any 60-87 Chevy truck. If you buy a crate motor, even a close to stock one, you will be paying about the same as a low mileage 6.0l Gen3 or 4 from the yard. Use Thealien's swap discussion and see what you thing. I am finishing up now and I, like most of us here, arent rolling in the dough. Single dad, one income, house and car payment just like us all. I started buying parts after reading the Classic Trucks magazine writeup. It took me about 3 months to gather the parts I needed, because of $ and no other reason. ( I wish I would have had Thealien's write up before I started) Then I jerked my tire 350/400 out and put the ls in, it was like it was made for it, I used the 4l60e trans for the 4speed and mileage. Everything is all done except the exhaust which I am currently saving for it, couple more weeks. It runs 10 times better than my 350, more juice and should get around 17-20MPG highway. Dont let this intimidate you, it is no more expensive than the crate motors and it will be a vast improvement over the gas guzzler you got. BTW I went with a 5.3l not the 6.0, just cuz I found it and the trans out of a wreck, with all accessories and harness/pcm under $1000.
Look into it, you will be glad you did.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#15 |
hands down ls based engine. run like a scalded dog, and great gas mileage. its not that much more. it would pay for its self in no time...
#16 | ||
#17 |
![]() Join Date: Jun 2009
I have a 350 and like it but curious as to why the 327 was endorsed by one poster as the best? Any advantages it has over the small block 350? Mileage? Power? Longevity?
Not a F*rd fan usually but their inline 6 300 was a fantastic motor, do the GM inline sixes compare? |
#18 |
283 or 307.As with all motors,the closer to the original design the better durability.These motors give enough power,last longer,and drink less gas.That`s best.If you mean best power get a monster motor and forget everything else.A 350 is 85 cubic inches bigger than the original design.I`ve defended the 400 and love them.Better hope one has another rebuild left in it.They are already bored.383?Cool motor.No matter what,you`ll add the cost of a new rotating assembly to the cost,though.A longer stoke motor works more per mile,don`t forget.Not a recipe for longetivity.
#19 |
![]() Join Date: Dec 2009
as far as the ls engines go ive put several together and its stupid easy to make gobs of power even with a carb. i pieced on together from ls1tech for about 2500 and it made almost 450 to the wheels. u just have to know what to look for.
#20 |
Ls swaps are getting pretty cheap. I see them on cl with trans and harness for $600 on ocassion.
Favorite I've had so far was a 400 small block. I had one in a caprice wagon- with a qjet and 700r4 I could get 20mpg. Took a trip from IL to NH and got 22 mpg, until I got in the mountains. I had a caprice/impala SS clone with an LT1 that I couldn't ever get better than 18mpg. |
#21 | |
#22 |
Reply to dccarpenter. Right - the 350s, 400s, BB402s here are good - love 'em all even with their differing characterisitcs. I'm responding to the aspects of the original question in this thread.
Yes, the 327 is more to the original block design if that matters (and it probably does.). It is a better balanced engine than the later derivations, seems to idle better and seems easier to fine tune, gives better fuel mileage (especially if you can live with a smaller cfm carb), and best for me - seems to get its power on at the right revs for a 3/4 ton truck. 2nd gear on a granny plus three speed trans with my rear is a dream gear and then it seems to be "just right" in 4th at 65 mph. This is what I meant by "best running". Now, if you want me to talk about why, after 39 years of driving it I like the 327 with big Holley and 365 hp in the 67 Sting Ray - well -----. CCCC
#23 |
pretty happy with my 400.
#24 |
I know the LS motors are better,but it's not an easy swap for the average guy!I like the 400,but most have been rebuilt once already,and they don't like much over .30.So a one piece main seal,vortec headed,roller motor might be the way to go.
It is now a 307 with the stock 2 barrel carb.Have any of you guys put the Vortec heads on this motor? |
#25 |
I agree with the 400. A stock rebuild is just a little more than a 350. If you want to stroke it to a 406, it's higher priced, but with Vortec heads, it really is a performance engine.
