Old 01-09-2010, 05:04 PM   #1
stevewhitmore
stevewhitmore's Avatar
Angry Rear Spring help
Hey Guys,
Trying to replace and put lowering coil springs on the rear of my 69 and cannot get the top bolts broke loose up inside the springs after days of soaking with penetrating oil and using a breaker bar to no avail and busted knuckles.
Any idea's, I am sure someone else has had the same problem.
Does this bolt screw into a weld nut or a regular nut? (that you can't get to)
Appreciate any help or thoughts
My only thought is to cut the springs up high with a cut off wheel and then try to cut the bolt head off?
stevewhitmore is offline   Reply With Quote
Old 01-09-2010, 05:32 PM   #2
cdowns
cdowns's Avatar
Re: Rear Spring help
thers a nut on the eend of the bolt
Old 01-09-2010, 05:45 PM   #3
Dynomutt
Dynomutt's Avatar
You can barely see the nut in this pic. It's not to tough to get to though.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 01-09-2010, 06:24 PM   #4
crushermechanic
crushermechanic's Avatar
you can break the bolt with a good impact and a wobble socket. i had the same problem with mine and thats what i did.
crushermechanic is offline   Reply With Quote
Old 01-09-2010, 06:37 PM   #5
hayhauler71
hayhauler71's Avatar
Cut the old bolts off and replace with new grade 8 bolts,washers and nuts.
hayhauler71 is offline   Reply With Quote
Old 01-09-2010, 07:28 PM   #6
stevewhitmore
Well I just stripped the heads off the bolts with the impact wrench so I guess I am cutting them off
