what's a marine engine?
what makes a "marine" engine different than a regular block?
Robert Olson Transport
![]() Join Date: Oct 2002
Re: what's a marine engine?
marine engines are made for the boat car engines are made for the car...some marine engines turn the opposite way of an automotive engine if memory serves correct
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Can someone explain how this would work?
1976 Chevy 1/2T 2wd SWB ![]() ![]() 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com ![]() |
It wont.... the 3 forward gears would become reverse gears. its not possible
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Badass
you gotta drive in reverse
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Also the flexplate is different.
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
The main difference is the camshaft. freeze plugs are brass. water pump impellor is brass. there are minimal differences. as stated some are reverse rotation which you wouldnt want.The cam used in most boat engines is a terrible cam for a street cam mainly due to operating range but its not a deal breaker.
#9 | |
The issue with cam timing in a marine application is the exhaust valve closing event. You want to make sure the exhaust valve is fully closed before the piston goes too far down on the intake stroke (ie little overlap). Otherwise, it can suck water in from the exhaust. This is reversion, and if you are not carefull with cam selection you may end up hydro-locking the engine. Other than this, and the above mentioned reverse rotation engines, there is nothing unique about cams used in marine applications. Cam lift, duration, lobe seperation, etc are all spec'd with the intended operational parameters of the engine. Marine engines need a lot of low end torque to get the boat moving and up on plane. And they typically have cruise rpm range much higher than an automobile engine. Therefore factory marine spec cams typically have a wider LSA to get a broader torque curve. But again, there is nothing terrible about that for street use. In fact, it is very similar to the popular RV cam grinds.
- Greg |
No No
Theres nothing magic about making an engine spin backwards it just requires a cam gound in reverse or installed 180* out an oil pump with reverse gear set and means to kick the engine over in the oposite direction. As long as you have a mount point for the starter, replace the oil pump and cam a reverse rotation engine is no different.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
The 305 in my boat is not very different than an automotive 305 of the same year. Its rated at 225 hp which is a bit more than the automotive 305s of that year. Big difference is the cam of course which is similar to an RV grind. Not sure on the heads, I'd have too look at the numbers again but this is a '78 so its likely smog style heads. Boat engines work twice as hard as a car engine so they need the power down low. The only other real difference on mine are the marine grade head gaskets and the marine grade starter. I run an automotive Holley carb. This engine if put in my truck would run just fine.
Addicted to Rust
![]() Join Date: Dec 2009
Cams are different and the firing order is backwards. The starter and flexplate are made to work backwards. I would assume that the dist gear is also different. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
If you convert a reverse rotation marine engine to standard rotation engine you will need to change-
camshaft,distributor,oil pump,starter motor,rear main/front crank seals,(yes these are different) and flywheel.
04 Yukon XL 2500 w/ Quadrasteer ![]() 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
The BBC in my boat does run "backwards", the top half (cam, distributor, oil pump) runs forward though. This is done with a special cam and timing set. Instead of a timing chain on two gears the gear on the cam meshes directly with the gear on the crank reversing the direction of rotation. This could be easily modified to run in a standard rotational direction. Hope I helped and not hindered.
#15 |
With a reverse rotating engine. OH just think of the fun you could have. What a wild mid engine off road buggy/sand drag buggy /mud bog buggy you could build. Perfect weight balanced! YEEEEEHAAAAA!!!
My Truck's not leaking its marking its territory! |
