Old 01-11-2010, 02:28 PM   #1
rogergodding
rogergodding's Avatar
Gremlins!!
My truck runs great and I've put a couple thousand miles on it lately. It just started dying when i go to stop at a light or when I am backing out of the driveway. Then it starts right up without a problem. I don't think it's a fuel problem since the engine doesn't rotate more than one time before it starts again and I don't have to pump the gas..... any ideas?
rogergodding is offline   Reply With Quote
Old 01-11-2010, 04:32 PM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Gremlins!!
check vacume lines, that would be my first idea
btw nice avatar
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-11-2010, 04:44 PM   #3
cdowns
cdowns's Avatar
Re: Gremlins!!
gremlins rock
Old 01-11-2010, 07:29 PM   #4
GREASEMONKEY72
Re: Gremlins!!
Originally Posted by cdowns View Post
gremlins rock
thats *****in
-steven
Alte Seele S.S.
Old 01-11-2010, 05:08 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Re: Gremlins!!
What's your idle speed set at?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-12-2010, 09:37 AM   #6
rogergodding
Re: Gremlins!!
not sure exactly what you mean, but at idle in park it is about 1000-1100 rpm and in gear about 750rpm....
Old 01-11-2010, 10:36 PM   #7
AH619
AH619's Avatar
Re: Gremlins!!
If you have a hei distributor?your feed wire might be losing juice when you step on the brakes?
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Old 01-12-2010, 04:50 AM   #8
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Gremlins!!
I once had a problem of my truck dying at stop lights or at the bottom of off ramps. I checked out my engine and found a cracked vacuum line. Fixed it and the problem went away.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 01-12-2010, 11:51 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: Gremlins!!
A little more info would help like engine, transmission, hei or points.
If it was running good before and nothing was done to the engine, then look for vacuum leaks as GreaseM mentioned. Carb base gasket and middle gaskets on quadrajets are know to come loose. Check all vacuum rubber hoses and flex and unflex them to see if you can find cracks.
If you have points, recheck the gap. I'd also check to make sure it's not flooding. Sometimes too much fuel especially during low idle will cause the engine to die. Quadrajets had problems with leaking plugs. Check for smoke when you first restart it.
68gmsee is offline   Reply With Quote
Old 01-12-2010, 07:18 PM   #10
rogergodding
Re: Gremlins!!
engine is a 350, th350 trans, accell hei..... edelbrock 600.... no smoke.....
