12-21-2009, 03:15 PM | #1 |
LS engine swap info
A lot of questions have been asked lately about LS engine swaps. I have done a bunch of research and wanted to share what I have found. I hope it helps some of you out. Spend some time clicking the links, I have put a lot of the time into finding this stuff.
LT1swap lots of good wiring harness info with pictures and DIY tips LT1swap Lots of good LS information, what are the engine differences etc LSprimer LSprimer part II A thread with LS engine swap questions and answers Questions and answers Another sites questions and answers ANOTHER Question and answer thread I will add to this post and thread as I go through my information |
12-21-2009, 03:16 PM | #2 |
Re: LS engine swap info
Here are a few Engine sources to look at. I only have experience with Spaulding Automotive. I will elaborate more when I finally start my build thread.
SPAULDING AUTO Here is a you tube link from one of their ads Spaulding auto ready to run package A couple people have bought from these guys Schram auto Pacific fab also does pull out and ready to run packages they also have a pretty cool 4X4 Ls crossmember I'll talk about later Pacific Fab Another vender that seems to have happy customers? TNScrambler And last but not least car part.com Car Part.com These are all just a reference, buyer beware and I am not recomending anyone at the moment. Ask questions, try local and good luck there are deal out there Last edited by Thealien; 01-27-2010 at 02:32 PM. |
12-21-2009, 03:16 PM | #3 |
Motor mounts and adapter plates
A couple of drawings of adapter plates, you would need two of either plate. This one would move the engine forward some. They are showing the wrong hole countersunk. The hole that should be countersunk is the one between the two 1.75 inch measurements. The point goes forward and to the top. You have to countersink the hole that ends up behind the motor mount. The two plates will be mirror images with the countersunk hole on opposite sides of the plate. This is more like most of the aftermarket adapter plates. Most of them are 5/16-3/8 while these are 1/4 inch. The slight thickness differences could change engine height. I haven't read much about anyone having any issues with any of the different thickness adapter plates. Scroll down S&P multi position adapter plates MULTI POSITION Moroso scroll down MOROSO Year one YEAR ONE Car Shop Car Shop And advance adapters. They are the only one that doesn't use the bottom bolt hole to position the motor mount? Hmmm Advance Adapters Now the drawings say 1/4 inch and all the rest are 5/16-3/8 which in my humble opinion will slightly change where your engine sits, higher/lower? There are some issues with crossmembers on the 4X4 trucks causing motor mount and crossmember problems. My truck is stock height so these won't work for me but 4" plus lifted vehicles can use these from Pacific Fabrication Pacific Fabrication Last edited by augie; 04-19-2011 at 11:31 PM. |
12-21-2009, 03:17 PM | #4 |
Wiring, harnesses, and connectors
If you want to modify your own harness there is some good info at LT1swap in the first post. Here is a list of links to places that either modify your own harness or build complete new ones. After contacting a bunch of them and having some emails go unanswered I am having my harness done by a board member 68 short step Check him out for your project Jims performance is very knowleagable and was the most reasonable. You must call him. Jims SPEARTECH Wait4me Current performance also has fuse/relay panels connectors and will either rework your harness or build new. Current performance LS1wiring harness Nelson performance In addition to currant performance here are a few places to get fuse/relay panels, connectors, pins and bulkhead connectors Pictures of GM connectors Bulkhead connector Terminals wire connectors If you know the connector part number and pin part number this is the place MOUSER Fuse blocks Fuse block wiring kits Painless circuit boss Painless Autotrend fuse relay The brake switch you will need if you want cruise control AC Delco D850A Last edited by Thealien; 01-24-2010 at 02:09 PM. |
12-21-2009, 03:17 PM | #5 |
Transmission info and adapters
If my transmission ever needs a rebuild I am going with these guys. Check out all the pictures and attention to detail! Finish Line Transmission build thread Not a lot of info to post here. The harnesses can be changed from either a 4l60 to a 4l80 and the other way around. It is easier to alter a 4l80 harness for the 4l60 but both are doable. The 4l80 has 2 VSS sensors and the 4l60 has one. If you have a 4l60 harness you have to add the other VSS for the 4l80. If you have a 4l80 harness you remove the extra VSS for the 4l60. It matters which one but if you are doing your own harness you will have the pin outs. If you are having it done they should know what to do if not find someone else. In the big round connector there are a couple of wires moved between the 4l60 and 4l80. HERE IS THE DIFFERENCES IN THE TRANSMISSION WIRING There is a big switch on the side of the transmission. It is your park/neutral safety switch. Many people remove this and that can be done. The PCM does use that information for more than the safety and gear indicator but from what I have read it is not necessary. Here is what I have found The PCM uses the signal to adjust idle speed based on whether the car is in gear or in park/neutral. As soon as the PCM "sees" the car go in gear it drops the idle speed by around 100 rpm to prevent jerking going into gear, and to prevent tugging at the torque converter. It can be considered as optional on a swap. As long as the line is left open the PCM will always assume the car is in gear, and will drop to lower rpm when the engine is started. This also causes a much quicker rpm rampdown on a cold engine start. Some aftermarket wiring harness companies that have no clue as to how the PCM works will wire this line to ground which makes the PCM think the car is always in park or neutral. On some applications this allows some diagnostic tests to be skipped (EGR, purge, etc.) so that these items can be left off without setting a code. The problem is that the idle is too fast then, and the car wantts to pull a little when sitting still, as well as other issues. I have a 4X4 and am keeping the NP205 transfer case in the factory location using the 4L60 transmission. Here are the aprts I needed to make this work. 4L60 to 205 Here are some of those parts being installed(bottom first page) And here is another thread showing more of that installation The transmission must be disassembled to install the output shaft. I did not want to move my transfer case shifter or change my almost new driveshafts so this is the route I took. There are a couple of passenger side drop transfer cases that will mate to the 4L60 but I do not have the information on what works and what doesn't. If somebody has information on what works and how they handled the shifter etc I will be happy to include it. With all that being said I may still have driveshaft/transmission pan clearance issues due to being stock height. I will update with pictures when I know. I am also going to try to modify my stock shifter linkage to work. Some say I won't be able to shift into first? Again I will update when I know. Here are a couple of shifter linkage solutions Lokar shift linkage Lokar cable shift linkage If you need to run a mechanical speedo with a 4L60 this is one solution Shiftworks The fittings on these 4l60/80 transmissions are not NPT but National pipe straight thread And use fittings like these Corvette servo information courtesy of Glock35ipsc Corvette servo Last edited by Thealien; 01-18-2010 at 12:51 PM. |
12-21-2009, 03:18 PM | #6 |
Cooling
Here is some reading on cooling that will keep you busy. I will add more later I am tired of typing. More than you thought there was to cooling A couple of thread on an ebay aluminum radiator. If you conatct him he will add steam ports, change inlet and outlet sizes, you can even get them with fans! Ebay Radiator Ebay Radiator 2 His Ebay store A fan install thread Frugal fan install Some hose adapters and steam port Ts Hose reducers etc. Look around this site a bit JTR |
12-21-2009, 03:18 PM | #7 |
12-21-2009, 03:19 PM | #8 |
AC compressor relocation options
THE EXPENSIVE ONES BUT??? A LESS EXOENSIVE SOLUTION BUT USES AN EXPENSIVE SANDEN COMPRESSOR AND HERE IS THE THIRD OPTION AC Compressor manifolds courtesy of Big Port Jimmy 6 search for AA2209 Docsblocks compressor manifolds Cable X box for running a mechanical speedo from a VSS Cable X Power steering pump info Use your old fitting on your new pump Link to torque values Scroll to the last 2 posts Aeroforce technologies. Cool little gauge that plugs into your OBDII port and has lots of programable features! AEROFORCE LQ4/LQ9 engine mechanical service manual thanks to 1972 supercheyenne LQ4/LQ9 engine service manual Last edited by Thealien; 02-11-2010 at 11:53 AM. |
12-21-2009, 03:53 PM | #9 |
Fuel system (any chance a mod can move this post up?)
The LS engines require 58-60 pounds pressure at the fuel rails. Older fuel rails had a regulator on the rails and there is a feed and return on these engines. On the later fuel rails there is only the feed on the rail. You need to have something like the filter regulator shown below to return the excess fuel to the tank. Some of the tanks these engines came with did this internally in the tank. Corvette filter/regulator I don't know how long this will last but a decent deal on the regulator/filter and he will take offers for less I am told GF822 Lots of people use Walbro external pumps Walbro external pumps and fittings Dorman quick disconnects for GM fuel line Dorman 5/16ths Dorman 3/8ths Russel AN quick disconnects Russel 3/8ths Russel 5/16ths Don't have a way to make the GM quick disconnect? Try one of these Dorman flare to quick disconnect Fuel pump tank adapter F-body LS1 fuel pump adapter kit here is an installation tutorial of the adapter kit Tutorial of adapter kit Another gas tank modification EFI pump tank mod Dual tank info Compliments of Glock35ipsc |
12-23-2009, 05:15 PM | #10 |
If you want to do your own computer tuning I suggest HPtuners
You will have to have some tuning done to remove at least the VATS. I would also assume most of us doing swaps will not be running a lot of the emissions equipment, so that can be removed from the tune as well. Once you get your engine up and running you can also edit other things like the timing and fuel curves (similar to re-jetting your carb and adjusting your distributor for the old schoolers). Additionally, if you run an electronically controlled tranny (ie 4L60E) you can change the shift parameters. Very usefull tool. But, be careful because if you don't know what you're doing you can blow up your engine or ECM. Also, this program allows you to monitor all of the sensors the engine is putting out, check and clear Check Engine Lights (DTCs) etc. |
01-27-2010, 07:57 AM | #11 |
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
04-23-2010, 10:10 AM | #12 |
Next project: 1970 K10
I put together a list of all the parts I used on my 85 to get the A/C hooked up and working. Keep in mind that all the part numbers listed for things like the accumulator, condenser, etc are for my 85, but might be the same for most 81-87's. 73-80 will probably differ, so be sure to check first.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
12-23-2009, 06:30 PM | #13 |
A couple of quick links to great LS swap articles:
CarCraft LS A-Body Swap Part I CarCraft LS A-Body Swap Part II CarCraft LS Swap Accessory Guide |
01-06-2010, 04:14 AM | #14 |
BAD BOW-Silverado XST
LS1 serpentine belt bracket modification
http://www.maliburacing.com/forum/vi...hp?=34&t=79059 77 with a LS1 5.3 swap http://www.hotrodlane.cc/77chevytruck/77chevy.htm |
01-26-2010, 03:45 PM | #15 |
Engine Torque Specs
Application Spec Accelerator Control Cable Bracket Bolts 89 lb in Air Conditioning Compressor Bolts 37 lb ft Air Conditioning Compressor Bracket Bolts 37 lb ft Air Conditioning Idler Pulley Bolt 37 lb ft Air Conditioning Tensioner Bolt 18 lb ft Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Bolts 15 lb ft Camshaft Retainer Bolts 18 lb ft Camshaft Sensor Bolt 18 lb ft Camshaft Sprocket Bolts 26 lb ft Catalytic Converter Nut 18 lb ft Connecting Rod Bolts - First Design (First Pass) 15 lb ft Connecting Rod Bolts - First Design (Final Pass) 60 degrees Connecting Rod Bolts - Second Design (First Pass) 15 lb ft Connecting Rod Bolts - Second Design (Final Pass) 75 degrees Coolant Temperature Gauge Sensor 15 lb ft Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed) 240 lb ft Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes) 37 lb ft Crankshaft Balancer Bolt (Final Pass) 140 degrees Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence) 15 lb ft Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence) 80 degrees Crankshaft Bearing Cap Side Bolts 18 lb ft Crankshaft Bearing Cap Studs (Outer Studs-First Pass in Sequence) 15 lb ft Crankshaft Bearing Cap Studs (Outer Studs-Final Pass in Sequence) 53 degrees Crankshaft Oil Deflector Nuts 18 lb ft Crankshaft Position Sensor Bolt 18 lb ft Cylinder Head Bolts (First Pass all M11 Bolts in Sequence) 22 lb ft Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence) 90 degrees Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head) 90 degrees Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence) 50 degrees Cylinder Head Bolts (M8 Inner Bolts in Sequence) 22 lb ft Cylinder Head Coolant Plug 15 lb ft Cylinder Head Core Hole Plug 15 lb ft Drive Belt Idler Pulley Bolt 37 lb ft Drive Belt Tensioner Bolts 37 lb ft Engine Block Coolant Drain Plugs 44 lb ft Engine Block Heater 30 lb ft Engine Block Oil Gallery Plugs 44 lb ft Engine Coolant Air Bleed Pipe Bolts and Studs 106 lb in Engine Crossmember Bolts (Large) 107 lb ft Engine Crossmember Bolts (Small) 92 lb ft Engine Flywheel Bolts (First Pass) 15 lb ft Engine Flywheel Bolts (Second Pass) 37 lb ft Engine Flywheel Bolts (Final Pass) 74 lb ft Engine Flywheel-to-Torque Converter Bolts 44 lb ft Engine Front Cover Bolts 18 lb ft Engine Mount Heat Shield Nuts 89 lb in Engine Mount Stud-to-Engine Block 37 lb ft Engine Mount Through Bolts 70 lb ft Engine Mount Through Bolt Nuts 59 lb ft Engine Mount-to-Engine Block Bolts 37 lb ft Engine Rear Cover Bolts 18 lb ft Engine Service Lift Bracket M10 Bolts 37 lb ft Engine Service Lift Bracket M8 Bolt 18 lb ft Engine Valley Cover Bolts 18 lb ft Engine Wire Harness Clip Bolt 37 lb ft Engine Wire Harness Ground Strap Bolt 37 lb ft Exhaust Gas Recirculation (EGR) Valve Bolts (First Pass) 89 lb in EGR Valve Bolts (Final Pass) 22 lb ft EGR Valve Pipe-to-Cylinder Head Bolts 37 lb ft EGR Valve Pipe-to-Exhaust Manifold Bolts 22 lb ft EGR Valve Pipe-to-Intake Manifold Bolt 89 lb in Exhaust Manifold Bolts (First Pass) 11 lb ft Exhaust Manifold Bolts (Final Pass) 18 lb ft Exhaust Manifold Heat Shield Bolts 80 lb in Exhaust Manifold Pipe Nuts 26 lb ft Front Shock-to-Engine Crossmember Bolts 48 lb ft Fuel Injection Fuel Rail Bolts 89 lb in Generator Bracket Bolts 37 lb ft Generator Rear Bracket-to-Engine Block Bolt 18 lb ft Generator Rear Bracket-to-Generator Bolt 18 lb ft Ground Strap Bolt (at Rear of Cylinder Head) 37 lb ft Ignition Coil-to-Bracket Bolts 106 lb in Ignition Coil Bracket-to-Valve Rocker Arm Cover Bolts 106 lb in Intake Manifold Bolts (First Pass in Sequence) 44 lb in Intake Manifold Bolts (Final Pass in Sequence) 89 lb in Knock Sensors 15 lb ft Oil Filter 22 lb ft Oil Filter Fitting 40 lb ft Oil Level Indicator Tube Bolt 18 lb ft Oil Level Sensor 115 lb in Oil Pan Baffle Bolts 106 lb in Oil Pan Closeout Cover Bolt (Left Side) 106 lb in Oil Pan Closeout Cover Bolt (Right Side) 106 lb in Oil Pan Cover Bolts 106 lb in Oil Pan Drain Plug 18 lb ft Oil Pan M8 Bolts (Oil Pan-to-Engine Block and Oil Pan-to-Front Cover) 18 lb ft Oil Pan M6 Bolts (Oil Pan-to-Rear Cover) 106 lb in Oil Pressure Sensor 15 lb ft Oil Pump-to-Engine Block Bolts 18 lb ft Oil Pump Cover Bolts 106 lb in Oil Pump Relief Valve Plug 106 lb in Oil Pump Screen Nuts 18 lb ft Oil Pump Screen-to-Oil Pump Bolt 106 lb in Oxygen Sensor 31 lb ft Positive Crankcase Ventilation (PCV) System Strap Nut (at Right Front Vapor Vent Pipe Stud) 106 lb in Power Steering Pump Bolts 18 lb ft Power Steering Pump Bracket Bolts 18 lb ft Spark Plugs (Cylinder Heads-New) 15 lb ft Spark Plugs (all Subsequent Installations) 11 lb ft Throttle Body Bolts 106 lb in Transmission Housing Bolt 37 lb ft Valve Lifter Guide Bolts 106 lb in Valve Rocker Arm Bolts 22 lb ft Valve Rocker Arm Cover Bolts 106 lb in Water Inlet Housing Bolts 11 lb ft Water Pump Bolts (First Pass) 11 lb ft Water Pump Bolts (Final Pass) 22 lb ft Water Pump Cover Bolts 11 lb ft T-56 Transmission Torque Specs Application Spec Backup Lamp Switch 20 lb ft Clutch Actuator Cylinder Bolt 71 lb in Clutch Housing Bolt 37 lb ft Control Lever Handle Bolt 18 lb ft Gear Select/Skip Shift Solenoid 30 lb ft Reverse Lockout Assembly Bolt 13 lb ft Reverse Lockout Solenoid 30 lb ft Shift Control Bolt 13 lb ft Shift Control Closeout Boot Bolt 18 lb in Shift Control Knob 27 lb ft Transmission Bolt 37 lb ft Transmission Drain/Fill Plug 20 lb ft Transmission Mount Bolt 38 lb ft Transmission Mount Nut 77 lb ft Transmission Support Bolt 66 lb ft Vehicle Speed Sensor Bolt 89 lb in
01-26-2010, 03:48 PM | #16 |
And here is the intake tightening sequence
01-27-2010, 11:21 AM | #17 |
Well umm no because I haven't figured that part out yet.
I will probably get the pro as it has a few more features. I am also looking at EFI live which has even more features (and maybe a little harder to learn?) but is more expensive. I just don't have the time to do all the research I need. I was originally going to go with an AEROFORCE GAUGE which lets you monitor most parameters and reset check engine light codes. But at $250 I figure I may as well get something I can scan/tune/data log for double or tripple that. I have not made a final decision yet. I wish someone local had one that I could watch and see it in use to help make up my mind. I am kind of a hands on kind of guy!
05-20-2010, 11:40 AM | #18 |
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 05-20-2010 at 11:42 AM. |
07-30-2010, 06:03 PM | #19 |
On the adapter plates, if you are going to run A/C with the compressor in the stock location, the 2nd plate won't work, because the compressor and engine mount would occupy the same space.
07-30-2010, 06:48 PM | #20 |
If you are using the plates and the LS's compressor, you can either use the shorter plate on the passenger side, or modify the longer plate to the same dims as the shorter one. Then either move the engine stand back about 2", or weld an extension to the back side of the stand to mount the rubber engine mount farther back.
08-24-2010, 07:53 PM | #21 |
Here's a great link I found on Street and Performance's website:
http://www.hotrodlane.cc/New%20LS%20...ks%20page.html
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-21-2009, 05:17 PM | #22 |
Random parts/links
Brass fitting and adapters LS engine pulling fixture Happy Hooker The last flaring tool you will ever need. Does the GM quick disconnects also and this is the best price I could find! Mastercool universal flaring GM Gen III & IV bolt and sensor list Bolts and Sensors There are not a lot of vacuum options on an LS manifold Vacuum manifold Some Vehicle Speed Sensor options VSS VSS OPTIONS BRAKE BOOSTER NIPPLE FOUND HERE Last edited by Thealien; 01-28-2010 at 11:06 AM. |
12-21-2009, 05:43 PM | #23 |
You are doing a great job, thank you for doing this, if I would have had that happen to me, my PC would be in the middle of the street and I with a sledge hammer hoisted high over my head ready for the explosion of PC parts all over the neighborhood, but that is me.
May I add this for cooling, I know it is from the F word car forum but this is what I am doing and it really cools my truck fast. http://www.fordmuscle.com/forums/coo...tric-fans.html
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-22-2009, 12:42 AM | #24 |
60-66 Nut
Thank you for putting this together. At some point in time I'm sure I will be doing a LS swap, so this will come in handy.
On the motor mount adapter plates there are two drawings, is one of each needed for a swap? One other source that I know of for wiring, connectors and a lot of other EFI related components is this one. http://www.eficonnection.com/eficonnection/default.aspx He does some really cool things like the 24X coil per plug conversion for older EFI engines. Just lots of cool stuff that he does.
12-22-2009, 07:52 AM | #25 | |
