Old 01-13-2010, 09:40 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
71 Ignition Switch w/ key AC Plenum AC Lines
Please do not PM with request to buy. Forum rules state that you need to reply in thread.
71 ignition switch w/ key. Came out of a running truck $10
Plastic underdash plenum for truck w/ AC. No cracks in plastic, but the door needs fixing. It is loose and may be broken $10
72 AC lines. These were removed fom a truck with AC. It has been a few yrs, not sure if it was a BB or SB truck, or if it matters. Rubber not cracked, not aware of any broken, stripped or otherwise defective areas $30
Prices do not include shipping
WIDESIDE72 is offline   Reply With Quote
Old 01-20-2010, 09:29 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: 71 Ignition Switch w/ key AC Plenum AC Lines
Ttt
Old 01-26-2010, 08:08 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
Ttt
Old 02-22-2010, 02:26 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
ttt
Old 02-22-2010, 02:38 PM   #5
ironhill
ironhill's Avatar
Put me up for the plenum, shipping to 59477. It flap is in good shape and moves freely? No brakes by the hinge? Mine is broke by the hinge. If thats all good I'll take it forsure. Thanks
ironhill is offline   Reply With Quote
Old 02-23-2010, 09:30 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
I will double check. It may be this weekend before I get a chance.
Old 02-23-2010, 09:44 PM   #7
ironhill
ironhill's Avatar
Sounds good, no hurry just let me know when you do check. Thanks again!
Old 03-02-2010, 08:27 PM   #8
ironhill
ironhill's Avatar
Ever get a chance to check out that plenum? Thanks
Old 03-03-2010, 09:21 PM   #9
WIDESIDE72
WIDESIDE72's Avatar
I got side tracked working on my washed out driveway and completely forgot. Sorry about that. I will make it my first priority tomorrow when I get home from work.
Old 03-03-2010, 09:59 PM   #10
ironhill
ironhill's Avatar
No problem, don't mean to rush you I was just checking, life does get busy at times. Thanks
Old 03-08-2010, 09:48 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
I finally got around to lookng at the plenum... I am sort of lost... There is a hard plastic flap in the center, with a rubber edge around it. THe hard plastic does not seem to be broken, but it appears that the rubber was leaking around where it attaches to the hard plastic, so someone used silicone on it. Also, it dodes not seem that the hard plastic center section is connected to the pivot directly. It is connected by the flexible rubber... I hope this makes sense... Does anyone else have any input?
Old 03-08-2010, 10:01 PM   #12
ironhill
ironhill's Avatar
Wierd? Yeah, should be a hard plastic with rubber around it. On both of mine the plastic is broken right where it meets the rubber at the hinge, which makes it kinda have a mind of its own.
Old 03-08-2010, 10:30 PM   #13
ironhill
ironhill's Avatar
I just took mine apart and pulled the flap out of it and it does actually connect to the pin with the plastic but is incased with the rubber must be to seal it, so if it moves back and forth while holding the hinge im guessing its broke just like my two. If I turned the pin it would actually rotate too in the hinge, which I'm guessing it ok, but Kind of hard to explain, but hope that helps
Old 03-09-2010, 07:54 PM   #14
WIDESIDE72
WIDESIDE72's Avatar
it sounds like the flap is broken on mine. Sorry to get you hopes up. I guess this is a pretty common problem...
Old 03-09-2010, 08:06 PM   #15
ironhill
ironhill's Avatar
Yeah thats ok, does seem pretty common. Thanks again
Old 03-31-2010, 01:14 PM   #16
WIDESIDE72
WIDESIDE72's Avatar
ttt
Old 03-31-2010, 02:13 PM   #17
truckpoorpackrat
How much to ship plenum to zip 64801 business. The case is good just the flap is messed up correct ? Thanks, James.
truckpoorpackrat is offline   Reply With Quote
Old 04-01-2010, 09:26 AM   #18
WIDESIDE72
WIDESIDE72's Avatar
The case is OK. There is one screw hole cracked out as seen in the photo. Not visible when installed. $25 shipped
Old 04-01-2010, 02:20 PM   #19
truckpoorpackrat
Thank you, but I'm going to pass. I should have known it would be more than $10.00 to ship. TTT for you. James.
Old 05-16-2010, 12:32 PM   #20
WIDESIDE72
WIDESIDE72's Avatar
ttt
