01-15-2010, 06:56 PM | #1 |
computer illiterate
i need help with tire size with a 4/6 drop
i am going to buy 20's tomorrow and new tires for my 2wd blazer. i have a 4/6 drop for it on order. what size tires can i run with no rubbing. i dont like the thin sidewalls.
72 2wd blazer 72 swb 4x4 |
01-15-2010, 07:00 PM | #2 |
Re: i need help with tire size with a 4/6 drop
I went with 295/40/20 in the rear of my 71 and it has been lowered 6 inches......I have 18's in the front so I cant help you with the front....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-15-2010, 07:11 PM | #3 |
67-72 parts collector,…
What size 20's?
01-15-2010, 07:12 PM | #4 |
computer illiterate
probably just 20x8
01-15-2010, 07:20 PM | #5 |
maybe a 245/40 up front and a 255/40 in the rear.
Some people run a 275/45 on 20x8's,...because they are cheap. But they are a pretty tall tire. |
01-15-2010, 07:31 PM | #6 |
On a lowered truck to this extent do you use the same back spacing as the original 15 inch rims or do you have to go with a positive back spacing to bring the rims in to prevent tire rub on the fenders. I've build a Ford f100 on a 72 C10 frame and have issues and need to know what size rim I can use on front. I have no idea of how to go about measuring for this. At the moment my tires are 1/2" from rubbing my fenders and no way of turning them and don't want to put it back up in the air.
01-15-2010, 07:33 PM | #7 |
computer illiterate
i believe with a 20x8 you want 4.5" of backspacing
01-15-2010, 07:38 PM | #8 |
01-15-2010, 08:24 PM | #9 |
computer illiterate
i have no clue. it would pull the rim/tire in 1.5"s more but i have no clue to answer your question...
01-15-2010, 08:40 PM | #10 |
Well thanks anyways, hope that someone here can help. Would you know how wide of a rim can be used on the front without steering problem like rubbing against tierod ends. I'm just trying to get a feel of what might fit my application. Where I live there is no one I can turn to for answers and with all the lowered rides on this site I might get educated. Hopefully my putting a ford on the chevy frame won't be to much of a turn off for everyone as I'm using what I had on hand
01-16-2010, 10:47 AM | #11 |
Just a bump in hopes of some help
01-17-2010, 12:18 PM | #12 |
computer illiterate
big al how wide are you wheels? what is the backspacing?
01-17-2010, 12:42 PM | #13 |
18x8 up front 4.5 backspacing
20x10 rears 5.5 backspacing If I remember correctly...
01-17-2010, 08:10 PM | #14 |
Hello big_al_71, do you think if those 18's on front had a 6" back spacing would they still turn and not rub the tie rod and actually fit past the steering knuckle. 18's is what I would like to run and hoping I won't have to go any bigger.
01-17-2010, 08:40 PM | #15 | |
I would suggest that you call Coys directly I cant remember the guys name but he was Coys son and he was super helpful..Mine clear with no rubbing at all stop to stop when you turn the wheel.
01-17-2010, 11:36 PM | #16 |
01-17-2010, 11:00 PM | #17 | |
A 20x8.5 with 5.5" BS will work. A 20x9 with 6" BS would be fine. I think a 20x8 with 6" BS will be tucked in too much. What width wheel are you looking at that has a 6" BS? Also,... what year truck are you putting these on and what do you have for suspension mods? Last edited by lolife99; 01-17-2010 at 11:02 PM. |
01-17-2010, 11:35 PM | #18 | |
01-17-2010, 01:18 PM | #19 |
computer illiterate
no rubbing issues al?
01-17-2010, 03:45 PM | #20 |
