Old 01-16-2010, 07:55 PM   #1
jgb7038
jgb7038's Avatar
My 70 Panel
I posted a couple of pics of my panel on the picture thread,and a number of you wanted to see some build pics. I took most of these with a film camera,and to get them on here,I took pictures of the pictures with my digital camera,(still havent figured out my scanner yet). So,needless to say,they are not the best,but you can get the general idea at least.
My panel was originally a long bed pick up.The truck was decent,but already made up of a number of other trucks, 70 doghouse and cab,72 doors and chassis,5lug disc,etc.It was no pristine original by any means. Once the panel conversion got into by head that all there was.I found a very rusty 72 burb at the local parts yard where I had been getting some other items. Got it for next to nothing,put the peices on a trailer and drug them back to the garage I was working in at the time.
This is how the truck looked a couple of days after I originally bought it.
The donor burb,
As you can see,the burb had a hard life.....
I wanted a shorter panel,so I cut my long bed frame down to make a "factory" short bed wheel base.With that done,I reinstalled the bed,cut off the front enough to center the wheel wells and welded the front edges of the bed onto the cab corners.Removed the back cab wall,and welded the bed floor to the cab.
I needed to cut the excess length off the rear of the bed before I could start fitting the burb on to it.
jgb7038 is offline   Reply With Quote
Old 01-16-2010, 08:11 PM   #2
jgb7038
jgb7038's Avatar
Re: My 70 Panel
One thing I forgot to figure in was the fact that the burbs have about 2" above the drip rail and pick ups dont.You can see how far off the roof lines were in the last picture in the prior post. My simplest solution was to wedge section the roof.Basically the burb roof tapers down,and the pick up roof tapers up.
With the roof panels aligned,it was time to start connecting the sides.I ended up cuttin the burb sides in a kind of a choppy way.I had to do this due to the fact of the bed side contures did not line up exactly. On the p/u.the main curve just below the bed rail tapers downward as it goes toward the taillights,and on the burb,it reamins staight across all the way back.I had to make sure there was enough of the burb 1/4 to line the contours up with the pick up.
On the in side,the inner and outer panels of the burb sat right down over the bed rails.
To finish out the rear,I reinstalled the lower sections of the pu bed.I also added the marker lights,and a late model fuel door.
Old 01-16-2010, 08:30 PM   #3
jgb7038
jgb7038's Avatar
Re: My 70 Panel
The burb had a tail pan that extended out to the bumper,which was mostly rotted away,so I used what I could ouf the sill and made a simple flat tail pan.
I used 18 ga. steel to fill in the window openings.
Now,at this point I was still using it as a driver.It took about 6 months of evenings and weekends to get it from a pick up to a panel truck. This was technically first part of the build.It had a well used 454 in it by this time that shortly gave up on me. Ened up having the motor rebuilt,but punched out to 496 cubic inches.While the motor was out,I ended up getting engaged,and as a joke I said "why dont we use the panel in the wedding" Much to my surprise my fiancee thought it was a terrific idea so begain build number 2.
Thrashing day and night for a few more months,this time in secret,the panel showed up on our wedding day dressed appropriatly.
Old 01-16-2010, 08:44 PM   #4
jgb7038
jgb7038's Avatar
Re: My 70 Panel
After being part of our special day,the panel went back to daily driver duty.
Ended up swaping the cut springs out for stockers so I didnt have as much trouble driving in the snow.
Wound up getting a "new" driver that got better mileage so the panel sat.........almost 6 years. Gathered parts as I found them thinking I would fix her back up some day....
That "day" arrived when I found a alston Chassis works full race rear clip for a price I could not refuse.So began build number 3.
The clip was a little narrower than I liked,so I split it in 2 and widened it.
Started cutting out the old making room for the new.
Old 01-16-2010, 08:53 PM   #5
jgb7038
jgb7038's Avatar
Re: My 70 Panel
With the rear end handled,It was time to prep the rest of the truck.I install steel wheel tubs,and sarted rebuilding the floor.with the rear clip and tubs so far up in the truck,I made a raised floor stucture and ended up with a couple of storage compartments behind each wheel tub.
Wheel tubs. Floor framing.
Old 01-16-2010, 09:04 PM   #6
jgb7038
jgb7038's Avatar
Re: My 70 Panel
One of the things to change was the headers.Bought a weld up kit and went to town.
Before and After in the truck.
After coating
Old 01-16-2010, 08:31 PM   #7
panelguy
panelguy's Avatar
Re: My 70 Panel
WOW!!! Thats some incredible work!!! nicely done!
66 Acadian 2 door
69 GMC panel truck
78 Chevy crew cab dually
79 Chevy blazer 2wd
01 Chevy silverado 2wd reg cab shortbox
panelguy is offline   Reply With Quote
Old 01-16-2010, 10:31 PM   #8
kev2809
low n' slo
kev2809's Avatar
Re: My 70 Panel
woooooooooooow! i never would have guessed you chopped a burb in half and welded it to your truck. looks amazing! kudos to you man, looks great!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-16-2010, 11:01 PM   #9
IAFF2407
IAFF2407's Avatar
Re: My 70 Panel
very nice, nice build thread. thx.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 01-17-2010, 12:57 AM   #10
pritch
pritch's Avatar
Re: My 70 Panel
I am just flat out amazed!!!! That is just plain awesome!
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 01-17-2010, 01:17 AM   #11
63chevyll
gets board easy.......
63chevyll's Avatar
Re: My 70 Panel
wow great job, Looks like a tone of work, we are all glad you took pictures
63chevyll is offline   Reply With Quote
Old 01-17-2010, 01:20 AM   #12
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Re: My 70 Panel
Super clean!
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 01-17-2010, 01:27 AM   #13
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Re: My 70 Panel
Thats Bad ASS.. When can I drop off my truck so you can start on it Its a short bed already so you wont have to cut the frame... Wellcome to the Board from Fremont Ca.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 01-17-2010, 01:33 AM   #14
pmpski_1
pmpski_1's Avatar
Re: My 70 Panel
pmpski_1 is offline   Reply With Quote
Old 01-17-2010, 01:39 AM   #15
Kayotic
Kayotic's Avatar
Re: My 70 Panel
I like that a lot, and thanks for the pictorial too...
I would like to ask about the seats though. Are they the off the shelf seats that Summit or Jegs carries?
I was planning on using them in my C10. Have you had much seat time in them? If so, any regrets?
- Danny
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 01-17-2010, 02:24 AM   #16
jgb7038
jgb7038's Avatar
Re: My 70 Panel
- Danny
Yes,the seats are from Summit racing.I could not get my old ones recovered for what the new one cost me. They are,in my opinion,very comfortable.My wife figits alot normally,but she doesnt in these seats. They are a good seat for the price.
Old 01-17-2010, 01:54 AM   #17
Rick Allmon
Rick Allmon's Avatar
Re: My 70 Panel
WOW! Dedication, Like most people we tend to lose a little of that on a major project, my hat is off to you and your girlfriend/wife. I've always owned some kind of wagon,panel,delievery,burp,or blazer. At this time I own 4 blazers,4 burps,90 something pick-ups, 1 57 chevy nomad,1 56 4-door wagon 1 57 2-door hard top[needs restoring.I do sale a few parts if anyone needs something,[nomad is not for sale. GOD BLESS Rick
Rick Allmon is offline   Reply With Quote
Old 01-17-2010, 02:50 AM   #18
suville
suville's Avatar
Re: My 70 Panel
Now thats a tough act to follow! NICE proportions too! Now lets stuff a big Block Caddy in that!
suville is offline   Reply With Quote
Old 01-17-2010, 03:09 AM   #19
67ss&99ss
Andy
Re: My 70 Panel
The build quality and fabrication skills are amazing! Very nice ride. Thanks for taking the time to post the pictures of the progress along the way.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 01-17-2010, 03:10 AM   #20
420am
420am's Avatar
Re: My 70 Panel
Wow. That turned out amazing. Very nice work.
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 01-17-2010, 03:36 AM   #21
KcLevi
KcLevi's Avatar
Re: My 70 Panel
Super nice. Looks great!!
1970 C-10. Black on outside Blue on the inside. Will be at least a 4-6 drop ASAP.
KcLevi is offline   Reply With Quote
Old 01-17-2010, 03:37 AM   #22
QKENUF4U
QKENUF4U's Avatar
Re: My 70 Panel
AWESOME MAN !!! atleast somebody in this country is makin good money.... glad its going to good use... congrats on the marriage and good luck.....
QKENUF4U is offline   Reply With Quote
Old 01-17-2010, 05:16 AM   #23
Sublvr72
Sublvr72's Avatar
Re: My 70 Panel
wow, that's awesome!
Sublvr72 is offline   Reply With Quote
Old 01-17-2010, 10:30 AM   #24
Hart_Rod
Hart_Rod's Avatar
Re: My 70 Panel
Very cool and thanks for sharing. It's always cool to see someone build something the General should have built, .
Hart_Rod is offline   Reply With Quote
Old 01-17-2010, 11:20 AM   #25
CG
BlahBlahBlah
Re: My 70 Panel
Thanks for the additional photos. Lotta work you put in for a unique ride, I like it.
