01-17-2010, 02:35 PM | #1 |
Lowered '64 trac bar & shock relocators
So I just ordered my 3/5 drop springs from CPP, but I'm cheap so I only got the spring and shock kit. From what I've seen it looks like I will need shock relocators and an adjustable track bar. Like I said I'm cheap, is there any way I can modify the stock stuff to work? Thanks, Barn-core.
Barn-core, contra mundum with a vengeance! "Our lady of blessed accelleration don't fail me now." |
01-17-2010, 02:46 PM | #2 |
Re: Lowered '64 trac bar & shock relocators
You can modify the track bar by cutting it, setting it at the length you need, and sleeve the track bar at the cut with a piece of pipe and weld it back together. That's the route I'm taking.
CPPJeff just posted a pretty sweet deal on adjustable track bars though, $50 for forum members in case you hadn't seen that post yet. I haven't decided on a good way to relocate the shocks for cheap, that's still on my list. Hopefully someone else will chime in with a good way to modify the existing components. Oh, and welcome to the board!
Andrew '69 C-20(292, 4-speed) Retired Daily Driver '64 C-10(250, 3-speed) Fixerupper '97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver If I only wanted two pedals I'd have bought a bicycle.
01-17-2010, 03:36 PM | #3 |
As MXmaniac indicated, shortening & re-welding the stocker is the cheapest option. You can also shorten it, thread the ends of each half cut (LH/RH thread), & use a tie-rod sleeve to make it adjustable.
CPP has a 'kit' currently discounted to board members that's a better deal because you really want the bar as long as possible to limit the amount of shift inherent w/a Panhard bar. You could do the adjustable set-up described above using 2 OE bars to end up w/a cheap, long, adjustable bar too. As for rear shocks, if you get some 67-72 rear lower shock mounts, you can tweak them so they function just like the brackets in a $70 shock relocator kit (the pre-67 lower brackets don't work well w/modifying)..... http://67-72chevytrucks.com/vboard/s...d.php?t=359399
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-17-2010 at 03:38 PM. |
01-17-2010, 10:51 PM | #4 |
Thanks for the info guys. What is the difference in the aftermarket shock mounts? I understand their purpose is to re-gain some travel after lowering, but what exactly do they do? How/where do they relocate the shocks? Maybe I can't modify the stock ones, but what about just making some from scratch. Also how do I measure for the correct length for my trac bar?
01-17-2010, 11:59 PM | #5 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-17-2010 at 11:59 PM. |
01-21-2010, 12:19 PM | #6 |
So how do I measure for correct trac bar length?
01-21-2010, 05:20 PM | #7 |
Hey guys the relocation kit and adjustable trac-bar we manufacture are both a must on any truck that has been lowered to the point where the shocks are laying on there side or the axle is no longer centered under the truck. Guys i understand money as it is tight for everyone so let me just give you guys a deal on the relocators and the bar. If you guys need pics of an install of those shock relocators let me know. Thanks
04-19-2010, 01:45 PM | #8 | |
need bolt in notch63-72cnk
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172 |
04-19-2010, 01:49 PM | #9 |
04-19-2010, 03:18 PM | #10 |
dang now thats a deal! already have me a trac bar though (cpp long length bar)
1967custom |
04-19-2010, 05:17 PM | #11 |
04-24-2010, 08:31 AM | #12 |
so is this the kit# 6572cdtbx because i just ordered and shock relocaters were an additional charge the price you im was fine but thought it included the shock brakets
shipping order has kenny light but its Tim light
04-24-2010, 09:21 AM | #13 |
You should prob call Jeff @ CPP. I wouldn't expect him to be able to decipher what you need (or want to know) by what you just typed. I had to read that multiple times & I'm still not 100% sure. Proof-reading & punctuation go a long way toward effectively communicating your needs (I'm not being the grammer police here either).
