Old 01-18-2010, 05:44 PM   #1
TwoFiftyShifter
Couple issues with 350TBI... related?
My 87 has the 5.7 TBI motor, and has a couple issues.... first the idle fluctuates alot of the time, 500rpm-900rpm and so on, I think it's the intake gasket. However, the truck is either burning or leaking oil. I burnt a quart in 50 miles today.... this happened tihs summer, anjd I got underneath and tightened the oil filter more (probably too much) and its held oil since. I changed the filter lip too, so that's not the issue.... It isnt smoking like crazy, it doesnt leave any puddles on the ground, I just want to know what it could be.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 01-18-2010, 06:04 PM   #2
68c10burb
Re: Couple issues with 350TBI... related?
some sort of vacuum leak would be my first guess, so intake gaskets may very well be it.
does it run fine everywhere else?
68c10burb is offline   Reply With Quote
Old 01-18-2010, 06:15 PM   #3
TwoFiftyShifter
Yes and I drove it 2.5 hrs last week all highway and got 15mpg....
1982 K10 SWB
Old 01-18-2010, 06:56 PM   #4
chevymotocross
chevymotocross's Avatar
I would do obvious checks for vacuum leaks. Also, do the testing procedures for the IAC. Maybe reset the IAC as well.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 01-18-2010, 07:13 PM   #5
SBTork
Garage wrench
SBTork's Avatar
Intake or throttle body leaking vacuum for the first one. Secondly, I would check you pcv system. Check the pcv valve, the tube from it to the throttle body, and so on.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
