Old 01-19-2010, 06:11 AM   #1
66coffin
66coffin's Avatar
c10 rear in a c20???
i want a five lug rear, is it possible to just instal a stock c10 rear end in my '66 c20? still use all the same trailing arms, brake lines, etc?
66coffin is offline   Reply With Quote
Old 01-19-2010, 08:58 AM   #2
jason65
Registerd User
jason65's Avatar
Re: c10 rear in a c20???
My 65C20 has a 65C10 rear end with a 5 lug cpp conversion.
jason65 is offline   Reply With Quote
Old 01-19-2010, 01:38 PM   #3
66coffin
66coffin's Avatar
what's involved with the conversion? what's different on the 2 rear ends?
Old 01-19-2010, 02:09 PM   #4
jason65
Registerd User
jason65's Avatar
The conversoin takes you from 6 lug to 5. You just have to swap out axles and put the new drums on that come with the kit. The 8 lug rear end is more heavy duty. I also moved my panhard mount "frame side" back about an inch to get it to line up again.http://www.classicperform.com/Store/.../6369RAC-5.htm You could use drums from your local parts house. Or.http://www.classicperform.com/Store/...k/6569RACK.htm
Old 01-19-2010, 04:24 PM   #5
66coffin
66coffin's Avatar
thanks jason65 for the insight, but do i just pull the 8 lug axles out and put in the 5 lug ones, is it that simple?
Old 01-19-2010, 05:18 PM   #6
Strider
Strider's Avatar
Hey team,
I'm going to take this a little further.
I have a 71 5 lug rear axle that I want to put into my 68c10 ( swapping front drums to discs with a set of cpp spindles).
So I want the front and rear to have the same bolt pattern (obviously!!!!!)
The 71 rear axle is a 12 bolt and the 68 axle is too.
The 71 has 3.73 gears and is a factory posi unit.
I was going to put 3.08 gears in it but it won't accept them according to what I have been told and even summit racing shows in their catalogue that there are 3 different carriers for the chevy 12 bolt truck axle.
I was hoping to go to more friendly highway gears but I can't do this with my 71 axle and my 68 axle has like 4.11 gears.
Any suggestions??????
I didn't want to have to find another axle or buy a carrier to fit. Perhaps I'm going to have to go with a 5 speed with overdrive and dump my powerglide!!!
Riley
1967 C-10 250 I6 w/ TH350 3.08 10 bolt HUGGER ORANGE aka "The General"
'57 GMC short step REGINA SPECIAL
2013 CREW CAB SILVERADO 5.3 6 SPEED Z71 WHITE DAILY DRIVER
"When you have eliminated the impossible, whatever remains, however improbable, must be the truth." ~Sherlock Holmes
"Deeds will not be less valliant because they are unpraised." ~ Aragorn
Strider is offline   Reply With Quote
Old 01-19-2010, 10:37 PM   #7
jason65
Registerd User
jason65's Avatar
Originally Posted by Strider View Post
Hey team,
Riley
Only suggestion I have is get a 60-66 chevy truck.
Old 01-19-2010, 11:27 PM   #8
Strider
Strider's Avatar
How will that help me?
60-66 trucks didn't have 5 lug rears!!!!!!!!!!!!!!!!!!!
Any other useful suggestions!!!!!!!!!???????????????
I really would like a 63 Chevy truck actually!
Old 01-20-2010, 12:56 AM   #9
Captainfab
60-66 Nut
To get 3.08 gears in that '71 12 bolt, you're going to have to change the carrier to a 3 series carrier....no way around it. You could most likely sell the 3.73's and factory posi to offset the cost. You may be able to find a 3 series carrier used as they are the same from '65 to '82 in the 12 bolt truck rear ends. Or as you said go to an OD trans.
Hey team,
Riley
Old 01-19-2010, 10:00 PM   #10
62 mark
62 mark's Avatar
The 3/4 ton axle won't accept the 1/2 ton axle shafts...but the whole 1/2 ton axle will bolt right in, as long as it came from a coil spring truck. what are you running on the front?
62 mark is offline   Reply With Quote
Old 01-19-2010, 10:35 PM   #11
jason65
Registerd User
jason65's Avatar
If you swap rear ends keep your C20 pan hard bar. It is longer than a C10. If you change to a C10 pan hard then you will need to change the frame mount. Just put the C10 rear end in and convert it. If your gonna do c-notches get ready to cut threw 1/2" of steel. C20s have an extra plate over the rear end. What are you gonna do to the front?
Old 01-19-2010, 11:30 PM   #12
63chevyll
gets board easy.......
63chevyll's Avatar
you may have to change to a special u-joint but i dont know for sure
63chevyll is offline   Reply With Quote
Old 01-20-2010, 12:06 AM   #13
66coffin
66coffin's Avatar
as far as the front goes i'm still on the fence, i need 5 lug but don't have the cash for a kit... any suggestions? i did convert the drums up front from drum to '84 disc but they are 8 lugs and i hate them!! can i put a 5 lug rotor on the '84 3/4 ton spindles? prob. not right? help.
Old 01-20-2010, 12:49 AM   #14
Captainfab
60-66 Nut
All you need to get 5 lug in the front is to get the lower control arm, spindles, rotors, calipers, etc from a '73-'87 C10 pickup, Suburban, or 2wd Blazer. You don't have to buy expensive aftermarket parts to do it. The parts you need should be able to be found in a local wrecking yard, or in newspaper classifieds, Craigslist, etc.
For the rear you just need either a complete rear end from a '64-'70 C10 and get the conversion axles, or a '71-'72 which already has the 5 lug axles.
Old 01-20-2010, 03:17 AM   #15
66coffin
66coffin's Avatar
Thanks captain!! You're helpful as always!!
Old 01-20-2010, 08:47 AM   #16
Strider
Strider's Avatar
Thanks for all the input and assistance!
You guys fruitin' rock!
Good luck with all your builds!
Anyone out there have a yj tub to sell me and are you possibly located in ontario, canada or minnesota or close by?????
Cheers!
rear end
