05-24-2002, 10:38 PM | #1 |
tip for disc brake install
i changed my 70 from drums to disc, the parts truck i bought is a 69 or 70 1 ton dump with power drums..i was only going to use the booster cause everyone always says that you have to use a disc master cylinder and proportioning valve....my buddy said he changed to disc in one of his trucks and left the booster, master cylinder and valve from drums and it worked fine so i figured i would give it a shot..well it works just fine...just thought i;d let everyone know...any one ever try this and it didnt work?
------------------ 70 short step from vegas woo hoo !!!Ken Lyons Slippery Rock PA yahoo messenger:mooneyes4b "things always look different from higher up" Clint Eastwood (fist full of dollars)
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
05-24-2002, 10:54 PM | #2 |
My kid brother was looking to do the same to his 70. We kicked around the same idea. Glad to see it works I will pass on the info to him.
------------------ 48 Chevy 3600 67 Pontiac Catalina 72 Chevy C 20 78 Chevy C 10 4X4 97 Monte Carlo 99 Sportster
48 Chevy 3600 67 Pontiac Catalina 72 Chevy C 20 78 Chevy C 10 4X4 97 Monte Carlo 99 Sportster |
05-24-2002, 11:22 PM | #3 |
its all about the +6 inches
Interesting, I tried using the disc booster on a drum truck with no luck.
Maybe it was me. Hmmmm... ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. E-mail longhornmail@yahoo.com My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough? Columbus Ohio |
05-25-2002, 12:30 AM | #4 |
the drum master has a residual valve to keep something like 8-10 psi line pressure on the wheel cyls,& the springs keep the shoes from contacting the drums. on the disc brakes,the ony thing that pushes the pads away from the rotors(when not using the brakes} is friction from the rotor turning. you dont want any pressure on the calipers while cruising,or you will burn the pads. I have always tryed to keep matching components together in a system.....My brakes are from a 75c 10(all pcs,from the master,prop valve,lines,hosesto the bottom)........69 longhorn.
http://community.webshots.com/user/hotrodhorn |
