66 292 help
like an idiot i must had my head up my a## i took out my distributor w/ot marking the location of my rotor...i know firing order is 1-5-3-6-2-4....so my question is when i get #1 tdc where should my rotor be pointing? p.s. i did mark where the vacuume was pointing on the distributor
Re: 66 292 help
Point it just past the number 4 , when you slide it in it should be right
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
Re: 66 292 help
Number one should be TDC on the compression stroke. Take out #1 spark plug and put your finger over the hole. You should feel air trying to escape from the hole as you rotate the engine in the correct direction. As the piston gets very close to TDC, like a few degrees before, the rotor should point to the tower on the distributor cap with #1 plug wire attached. That should get you close enough to get it running and use a timing light.
Re: 66 292 help
right now i have it pointing to number one piston... i know the piston is all the way tdc but no idea if its compression... i have my wife bump it but she hold the key too long lol ill just have to wait till tomorrow to get a buddy to help me with it...
"the rotor should point to the tower on the distributor cap with #1 plug wire attached". do you mean the rotor should be pointing towards number 1 on the cap if it was on...that is also pointing towards #1 cylinder am i right? |
Re: 66 292 help
Yes. You might even consider setting the cap on the distributor and drawing a line with a Sharpie on the base of the distributor that corresponds with #1 plug wire. That way when you take the cap off to watch the rotor, you'll still be able to tell when it lines up correctly.
Re: 66 292 help
i got it.... but now i am not getting no fuel...i unhooked my fuel line and turned the motor over and no fuel out of the line so i am assuming bad pump....
Re: 66 292 help
could be pump or one of the 44 year old fuel lines you may as well change them now
