1968 K10 Help
I'm a newbie at this and hopefully ya'll can provide me some help. I've own this truck since I was 16 years old and I have to put my truck on hold for a few different reasons: Join the USMC for eight years, got married, money problems, and a couple of other things. I had to take a job out of state and then out of the states for money reasons. Now I have some spending money and would like to get er' running after all these years. I've already got a rebuilt 327, good 465/205, new clutch, fixed up the cab and interior, new cooling systems, all new wiring harnesses, and brand new hard and soft brake lines. I also bought a 76' 3/4 frame for the axles for a future axle swap. It's going to be my hunting/fishing/slight trailing/everyday work truck so I don't need a ton of fancy parts. Just 33's or 35's and 4-6 inch lift. My body and drive train is all good so here is my dilemma:
Looks like the previous owner got into a slight wreck and screwed up all my suspension brackets (truck dog legs down the road) or my axles are bent, but the frame measures good. I was wondering if my 68' body will swap onto a 69-72 K-10 or K-20 frame with any major snags? I've already contacted DIY4X and he is non exactly for sure if the FGB-52 brackets will work because it is designed for a 69-72. I've already threw out the idea to him that if he wants he can us my truck for R&D, but not for sure if he has time for such an oddball year truck. He's very polite and a busy guy. Do ya'll think it's a better route for to do a frame swap (69-72), or try the FGB-52's? I really appreciate all the help and will post pics whenever I get back to the states and start working on er'. Thanks again. Last edited by 1968filbilly; 01-23-2010 at 08:14 AM. |
Re: 1968 K10 Help
I'm 99.9997% sure that 68 body will bolt right on a 71 or 72 4x4 chassis. I'd stick with 71 or 72, they already have disk brakes.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Re: 1968 K10 Help
Before you spend money on a different frame (unknown if wrecked) I would take yours to a body shop with a frame rack, it might not cost that much to fix and shouldnt cost much to get an estimate.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin ![]() 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) |
![]() Join Date: Aug 2004
Re: 1968 K10 Help
X2, it may be cheaper and easier in the long run to get your frame/mounts trued up, you could just have way worn out bushings causing this.
You also get to keep the matching VIN your frame has. It could save you a title fiasco if you move to a state that is picky about that sort of thing someday.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Re: 1968 K10 Help
The lift kits options are pretty limited and when I threw on a 4 in lift, I noticed that my driver side leaf spring hanger was bolted on!!! The rivets were missing and the plate was all bent up. I got a buddy to fab up a new mount with 1/4 plates, bolted everything on, then i noticed that the leaf spring angled inward, towards the engine. The rear shackle hanger was messed up, but I didn't have any problems when I install a stock replacement shackle kit. That's why I was very interested in the fgb-52, but not for sure if it will work or not. Has anyone installed a fgb-52 kit on a 67 or 68'???
Appreciate all the input. |
Re: 1968 K10 Help
I found a 71 4x4 chassis for my 67 2wd, it is a easy bolt on and while you are at it you can put on new body mounts and/or a body lift.
