01-25-2010, 10:16 PM | #1 |
Redefining LowBudget
drilled drums??
has anyone drilled drumes like they drill discs to let gases out and help cool??
I was just woundering if there was any advantage to it?? I want to tow my boat with my truck so thought about brakeing..my truck is Drum/drum and I plan to add the power to them this spring
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
01-25-2010, 10:35 PM | #2 |
Re: drilled drums??
ya I drill my drums, a lot of ppl thought I was crazy but it works good. I race circle track and we're not allowed to run rear discs and get a bit of brake fade 15 laps in, after I drilled them it's not as bad. It lets out some gases and dust, other guys I race with slot theirs. I'm the only one that has drilled so far. I'll see if I can get a pic and post it up
01-25-2010, 11:02 PM | #3 |
Re: drilled drums??
Converting to power brakes with discs in the front will be more than enough. If you REALLY cant stop your truck with that than you may be towing a bit much.
1970 Short/Fleet C-10 (Project) -Slammed and Tubbed 1955 Cameo -Straight six, Turbo Hydro option 1955 BelAir 2 door post -All original down to the oil bath air cleaner 1964 Corvette -All power A/C 327 4 spd. tanker |
01-26-2010, 08:27 AM | #4 |
Re: drilled drums??
the boat I have is a 21 footer with a big block...I think it about 3500lbs...not alot and I tow alot and know about saving your brakes and giving some room....some day I may goto disc but not anytime soon looking to make what I have the best it can be?
01-26-2010, 09:51 AM | #5 |
Re: drilled drums??
drilling a component that is exposed to this extent of centrifugal force not to mention being made of cast iron is probably not a good idea for a street driven vehicle.
01-26-2010, 10:39 AM | #6 |
Re: drilled drums??
they drill and slot rotors all the time and they deal with alot more heat
01-26-2010, 11:19 AM | #7 | |
Re: drilled drums??
The majority of braking is done with the front. Disc conversions can be done on the cheap. Brakes is not somewhere I would want to experiment on a street vehicle. A disk conversion is much cheaper than a wreck because of a failed drum. Just my .02 How bout some pics of the boat?
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 01-26-2010 at 11:20 AM. |
01-27-2010, 02:05 AM | #8 |
Re: drilled drums??
As a brake technican working on brakes all day, I have seen drums that have broken or for better explaination come apart. Although Im too young to have been around when it was a fad, I can imagine to do it properly on a dd would take some very good finese and engineering, not to meantion that it would probably need to be rebalanced. In regards to your remark about them doing it to the rotors all the time, have to remember that 99% of the time, those rotors are steel and not cast iron. I would recommend that your equip your trailer with trailer brakes. They are pretty simple to install, and Im sure your axles on the trailer already has the flange for it. 4 bolts and two wires to your plug and away you go. Best of luck with your decision and keep on truckin
- 1967 Chevy C10 shortbox - 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project - 1986 Chevy K10 LWB 350/350 Daily Driver/project |
01-27-2010, 09:00 AM | #9 |
Re: drilled drums??
Smallz72..those breaks DO NOT WORK...you have to relize that they are boat trailers ...yes they have a hydralic system that you can put on them but its VERY pricey and they still dont last long due to rust..they last about a year if you deal with salt water ..which thankfully I don't deal with
as far as drilling my own I thnk I;m going to pass..it looks like lots of hours to drill them out myself..it looks like alot of holes X 4 drums
01-27-2010, 09:04 AM | #10 |
Re: drilled drums??
Was just making a suggestion, and true they dont always work properly but if a person was able to swing the cost might be something to get by with, but I agree with you, again just a suggestion. Those brothers drums look like they might be a decent option. Keep on Truckin and have a great day!
01-26-2010, 11:13 AM | #11 |
Re: drilled drums??
ok. go for it.
01-26-2010, 11:55 AM | #12 |
English Chevy Owner
Re: drilled drums??
I'd have thought you'd drill the back-plate rather than the drum itself to let some heat out. I've seen hot rods with drum brakes with drilled back plates and a little scoop facing the front to funnel more air in.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
01-26-2010, 02:00 PM | #13 |
Re: drilled drums??
I pull my 3200ish pound bass boat all over the state with my truck however it has front disk brakes.
Back in the day, when my 72 Chevelle was my daily driver, I pulled a little 14 foot boat around. Back then my Chevelle still had it's factory, manual front drum brakes. One stop was it for those brakes. After that I REALLY had to plan ahead. I would never consider attempting to stop a 4000+ truck and a 3500 pound boat with front drum brakes. Power drums or manual.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
01-26-2010, 03:23 PM | #14 |
Re: drilled drums??
drilled or slotted rotors are okay, on the street. the drums should stay intact.
when a rotor is drilled or slotted you are talking a 1/4" hole.not much chance of getting a rock or other junk in there. the rotor is already vented around its outter edge and has vanes that force air up through the middle for cooling. the holes and slots let gasess created when braking hard escape so that the pad will still contact the rotor surface properly. when you drill a drum you have to drill a 1-1/2 hole to get enough air across it to affect the cooling of the drum and pad and a hole that big can let in bad stuff. rocks, mud etc. thats why they make that rubber plug for the adjuster hole. water and mud inside a drum is not good. drilled drums on a race car make a little more cents, because race cars aren't tippically driven through pot holes and mud holes on a regular basis, and any unsprung weight you can remove is a bonus. also a brake drum is a very brittle casting. i have never seen one come apart but i bet its an awesome thing. admittedly i am not an expert but for me , i don't think i would do it on a street ride. best of luck to you in whatever you decide. Tony
i survived cancer and kidney stones, but my kids are killing me. |
01-26-2010, 04:41 PM | #15 |
Re: drilled drums??
thanx for everyones input I think I'll pass on this bright idea..thank god you guys are here to talk me out of some of my BRILLENT Ideas I guess its winter time and I'm looking for small projects that I can do in the cellar with some of the extra parts I have or plan to upgrade this spring....I have a ton to do but the cold garage is killing me....
as for the boat well theres 3 of them I tow 1st on is 750lbs with me in it runs 87 on gps...the second is 1100lbs with me in it and runs 143 on gps but the anchor of the fleet has a BB and a bravo drive guess the weight to be about 3500 lb with all the BS and coolers its a bull dozer and runs in the high 70's with 2 or 3 in it
01-26-2010, 06:41 PM | #16 |
Re: drilled drums??
01-26-2010, 06:46 PM | #17 |
68 C10 SWB
Re: drilled drums??
I have a question regarding towing. I have a car that has a curb weight of 3175 lbs. Is that plus a trailer too much for my 72 with a sb350 and TH350 trans?
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman |
01-26-2010, 07:09 PM | #18 |
dazed and confused
Re: drilled drums??
i remeber Performance online or somebody offering a drilled brake drum i think.
members met: redbaron69, billsbowtie,nc67 |
01-26-2010, 07:20 PM | #19 |
I am a Referee of life.
Re: drilled drums??
Drilling drums was done quite a bit "back in the day".I've been told it helps some but have never done it myself.I do know that evenly spaced holes are required to keep the drum where it is "balanced".There was an article about it in R&C,Street Rod or one of the other mags.They seemed to think it was an OK addition for cars that didn't have other remedies for brake improvements.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-26-2010, 07:23 PM | #20 |
Re: drilled drums??
we used to drill the backing plates and put scoops on them too back in the 60's early 70's circle track cars i worked on
01-26-2010, 07:22 PM | #21 |
Re: drilled drums??
I can believe it my drill press is from the 30's...you cant tell me that lookiing at there equipmnet ther is any brain surgery to it...what ever you do to one side you do the the other to keep it balenced...
still not sure I'm ready to dive itn but it was an Idea I had while sober?? Marc does your trailer have brakes??? your truck is a disc brake truck so brakiing isn't such an issue but there are other factors like how many axles on the trailer
01-26-2010, 09:48 PM | #22 |
Re: drilled drums??
drilling drums was a fad back in the 80's Its a very very BAAAAAD idea. the drums will crack over time and at some point when you really need them they wil simply brake up into chunks and whith them goes your park brake. Dont do it. Its a very bad idea.
01-26-2010, 10:23 PM | #23 |
Re: drilled drums??
Nice Boats, I really like # 2 & 3. What make is #3? I have a 83century cuddy 4000 which is 22 footer and damn that thing is heavy. I pull it with my 72 that has disc/drum. This past summer I really found out how hard it was to stop it after I came up on my turn quicker than expected. I did make the turn but it was almost too late. The pig was pushing my truck. That has made me decide to do some brake upgrades on the boat trailer not the truck. The boat trailerr used to have trailer brakes but the p.o. must have put it in salt water a time or two and the lines rusted and fell off. So this year I plan on puting the brakes back on the trailer. Should make a world of difference. As far as your truck. Upgrade to power disc/drums. You can find the parts in alot of yards. If you cant find any let me know. I went to a yard the other week and they had several out there with power brakes. If I can figure out how to make the booster m/c and prop valve work that I got off of a 93 burb to work on my 72 then You could get the set up from my truck.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. |
01-26-2010, 10:54 PM | #24 |
Re: drilled drums??
here you go, brothers sells them already done for you
http://www.brotherstrucks.com/prodin...ber=FMA5170-XD |
01-26-2010, 11:22 PM | #25 |
Re: drilled drums??
And bookmarked! Somehow, I was thinking drilling through the face of the drum.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
