C30 cab on c10?
Hey guys, quick question, a c30 cab fit on a c10 chassis? Im getting a BBW, A/C cab with minimal to no rust, and just want to make sure it will fit alright.Thanks!
1961 crewcab
Re: C30 cab on c10?
It will bolt right on... remember that 60-62, and 63-66 use different front mounts, and require some fab work to interchange.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
60-66 Nut
Re: C30 cab on c10?
![]() What Jon said.....
Re: C30 cab on c10?
Cool, both are 66' cabs so shouldnt be a problem. thanks guys!
Re: C30 cab on c10?
The rear cab mounts on the C20 & C30 cabs are different than the C10 rear cab mounts, but that is easily addressed.
Re: C30 cab on c10?
LIL RED, do i need to change the mounts on the frame then to accomidate the c30 cab? or do the c10 ones work?
#7 | |
Re: C30 cab on c10?
www.lmctruck.com www.classicparts.com www.bowtiebits.com www.oldchevytrucks.com www.truckandcarshop.com If you need any help, send me a PM or give me a call and I will help you, otherwise good luck and let us know how things work out. |
Re: C30 cab on c10?
I really don't think the rear cab mounts will have to be changed. I've got a c-30 parts truck myself and have noticed the different cab mounts as well. As far as I can tell, the way the 2 mounts attach to the cab and frame are identical. the only difference is the c-30 cab mounts have rubber sandwiched between the part that mounts to the frame and the part that mounts to the cab. I'm sure this was in an effort to keep the c-30 trucks from beating the driver and passengers to death due to the massive spring packs in the back of the ton trucks.
1961 crewcab
Re: C30 cab on c10?
you just need to reuse your c/10 rubber bushing for the rear mount.
Re: C30 cab on c10?
Reusing rear cab mount rubbers is usually not possible, since they have been flatten over the past 40+ years, so I think you should install new ones, while the process is easy and it helps to maintain the correct height of the body lines of the cab with the bed.
1961 crewcab
Re: C30 cab on c10?
thats probably what i am chasing on my 61....
