whos had?
one of the bolts that tightend the transpan to the tranny strip before?
how did u fix it? |
laying low
![]() Join Date: Mar 2001
Re: whos had?
Aluminum housing, no problem. Go to parts store and check out a helicoil kit. Fix it right up.
Re: whos had?
ya i have a kit but i didnt know if it would crack when i make the new threads
Re: whos had?
on my doors when they stripped out i welded it shut.. drilled a pilot hole then used a bigger bit and redrilled it and threaded it.. u can try same way with the housing just switch to a spool gun aluminum welder..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
User #12137
![]() Join Date: Apr 2004
Re: whos had?
easy fix, take a small carter key and unfold it put the unfolded part in the striped out hole and start the bolt in there and your done till you have to change it again .
not the best fix but it works , i worked part time at a trans shop back in the late 70s and thats how they fixed them |
