Old 01-29-2010, 03:14 PM   #1
67chevy2wd
67chevy2wd's Avatar
How do you change the window felt?
I am changing all the seals for the windows on my doors. I have figured every seal out except the felt one attached to the vent window. How do you go about removing the old one?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 01-29-2010, 03:22 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: How do you change the window felt?
You cut the cloth at the edges and scrape it out. The new ones glue into the channel once you have it cleaned up. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-29-2010, 05:42 PM   #3
67chevy2wd
67chevy2wd's Avatar
what do I use to glue it in
'71 GMC 3/4 ton 4x4
Old 01-29-2010, 05:57 PM   #4
Classic Heartbeat
Any good weatherstrip glue. Gorilla, 3m, All parts stores sell it. Just do not use silicone based adheisives. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 01-29-2010, 06:12 PM   #5
rodstored-72
chevy truck fan
rodstored-72's Avatar
i hope this is not hijacking.... but i was wondering if that seal is a repop part & if you buy it does it come with everything needed to replace the old existing ones (minus the "glue")? also Wes by chance do you offer the replacement(s)??
thanks!!
rodstored-72 is offline   Reply With Quote
Old 01-29-2010, 06:38 PM   #6
Classic Heartbeat
Yes I do offer the replacements. The division bar felt (the one we are talking about here) just gets glued into the channel. No other parts needed. The channel run is a friction fit that does not require adheisive of any sort. The squeegee, and fuzzy otherwise known as the anti rattle set comes with the clips needed preinstalled. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 01-29-2010, 06:46 PM   #7
1-PU70
1-PU70's Avatar
When you replace the division bar felt does the door glass (the glass that goes up and down) have to be removed?
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 01-29-2010, 07:48 PM   #8
Classic Heartbeat
Yes it does. The Vent window assembly should be removed to ensure propper cleaning and installation. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 01-30-2010, 07:55 PM   #9
D-Rat
D-Rat's Avatar
since we're on topic, can the outer window seal on the door at the bottom of the window be replaced without window removal? Looks like it just pushes in. Does it also have to be glued?
Getting water in my door when it rains, and it bubbled my door panel a bit (Grrrr!)
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 01-30-2010, 08:16 PM   #10
67chevy2wd
67chevy2wd's Avatar
Yes, they just clip in. The old ones were hard to remove though. Maybe someone else has a tip on how to remove them.
'71 GMC 3/4 ton 4x4
Old 01-30-2010, 10:01 PM   #11
Diablo de la Noche
Diablo de la Noche's Avatar
I don't mean to hijack the string, but it seems to fit really well.
Had to discontinue my project for a couple months, so can't remember the particulars. But, when I put in my vent window rubber, it seemed really difficult to seat at the bottom corner. I figured it would seat itself after a little while but it didn't. Now, with the vent window all put together (on the door and everything), the bottom of the rubber seal bows out/up at the bottom. What can be done?
www.coolmoodart.com
Diablo de la Noche is offline   Reply With Quote
