Old 01-29-2010, 04:18 PM   #1
72bigred
Gas Tank..
I was looking for opinions on who sells the best tank. My 72 Blazer tank is full of rust and to have it cleaned/sealed locally will be upwards of 200$.. Looking at LMC I can replace it for less. There are other companies that sell a poly tank also. I was wondering from your guy's exp what the best route is to go and who sells quality.
Thank ya,
Reid
72bigred is offline   Reply With Quote
Old 01-29-2010, 04:28 PM   #2
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: Gas Tank..
tagging along,
I just picked up a 72 Blazer that has a monster sized gas tank, and would like to hear about options too.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 01-29-2010, 07:00 PM   #3
pound41
Re: Gas Tank..
I got a metal one but I all think they sell the same one from one manufacture
I am sure someone will chime in. If you go metal you will need to have your old neck welded on. Also the original straps are much better fit. The repo tank is a hybrid suburban/blazer tank
pound41 is offline   Reply With Quote
Old 01-29-2010, 07:25 PM   #4
theboxer
Re: Gas Tank..
I replaced mine with a LMC tank. Do not discard your old tank, you will need to transfer the inlet to the new tank. I had a heck of a time finding the replacement hose but I found one at Classic Chevy out of OKC.
theboxer is offline   Reply With Quote
Old 01-29-2010, 11:13 PM   #5
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Re: Gas Tank..
I build a nice low profile Blazer tank....
FuelCellGuy is offline   Reply With Quote
Old 01-30-2010, 12:24 AM   #6
jaros44sr
jaros44sr's Avatar
Re: Gas Tank..
Dang it, and I just told my wife I didn't need to buy anything else for the truck. I was down to 4 tires, 2 batteries, a quadrajet, and a partridge in a pear tree. Wonder IF I could hide this one somewhere, really do need a fuel cell
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-01-2010, 08:51 PM   #7
70BLAZERX2
Re: Gas Tank..
Hint...Hint...if your old rusty tank is not leaking...remove it out...empty all big rust from tank...fill the tank full of hot water....Add one can of crystal drain o cleaner..and tilt it side to side for about 10 minutes...drain out...rince with cold water...then put a gallon of paint thinner inside. slosh it around.for final rinse..then reinstall... I have done this alot..and only costs about $30...And a few hours work..
PS also cleans a ratiator out very good too...
70BLAZERX2 is offline   Reply With Quote
Old 02-04-2010, 09:46 PM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Gas Tank..
Try this link:
http://67-72chevytrucks.com/vboard/s...highlight=tank
I bought a steel tank kit from Brothers, replaced the fuel neck, painted and reinstalled. Its not a weekend job from start to finish.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 02-04-2010, 10:49 PM   #9
SeventyOne
Re: Gas Tank..
they sell kits for rusty tanks that clean them out then reseal them.
here is one from por15:
http://www.por15.com/Fuel-System-Res...n/products/12/
SeventyOne is offline   Reply With Quote
