01-31-2010, 12:02 AM | #1 |
60-66 Big Red Heavy Chevy C60
Ha, Look what I found. Right out in the open. Drive by this lovely, on my scooter, for about 4 years now, never gave her a thought. I think I'm in love. bushy
01-31-2010, 12:12 AM | #2 |
Re: 60-66 Big Red Heavy Chevy C60
Sorry about that, a little fussy. Here she is when I put my glasses on. bushy
01-31-2010, 12:27 AM | #3 |
meowMEOWmeowMEOW
would make a sweet hauler
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
01-31-2010, 01:06 AM | #4 |
br3w City; If I have my way she'll have an 9' crysteel dump body upfit on to it. You know with drop down sides. Deliver you some dirt man. Cream color rims, mirrors and grill. That what I'm talking about. bushy
01-31-2010, 08:30 AM | #5 |
1961 crewcab
If the emblem on the side says c80, it probably has the 409 in it...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
01-31-2010, 08:55 AM | #6 |
Pretty sure it says c60. What motor would it have then. bushy
01-31-2010, 09:05 AM | #7 |
and a few others
That thing looks to be in really nice shape for a heavy hauler. Budd wheels too !!
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
01-31-2010, 09:27 AM | #8 |
1961 crewcab
I think the c60's would have been the 6, or the 283/327...
01-31-2010, 12:50 PM | #9 |
meowMEOWmeowMEOW
a 6 with that much weight behind it would be anemic.
that thing needs a diesel or big block imo.
02-01-2010, 01:46 AM | #10 |
60-66 Nut
My '63 C60 has the 292 with a 5 speed and a 2 speed rear and it does pretty darn good. I've rolled down the road at over 20,000lbs with it. It doesn't get up to speed real fast but it does do it.
01-31-2010, 01:45 PM | #11 |
I have a 292 in mine hauls loads just fine its all in the gearing 2 speed axle
01-31-2010, 10:31 PM | #12 |
j.kirn 292 motor, things like starter and alternator still readily available? I think I have a 292 in my 69 c10. bushy
02-01-2010, 01:50 AM | #13 | |
60-66 Nut
I've not had any trouble getting parts for mine. Needed a water pump a few years ago....no problem. The 292 was in production up thru 1980 I believe. Some things are interchangeable between the 292's and the 250's and 230's, like the later model HEI distributors.
02-01-2010, 11:09 PM | #14 |
Captainfab: Thanks for the feed back. Nice workmanship on the booster bracket. What's the idea? It allow you to use a newer year booster on an older truck. bushy
02-02-2010, 02:12 AM | #15 |
60-66 Nut
That is correct....and it is 100% bolt on except for modifying the booster pushrod.
02-01-2010, 11:39 AM | #16 |
YOU will not have any problems getting any parts for the truck the only thing hard to get is brake drums but if you need any parts let me know and i will fix you up
02-01-2010, 11:43 AM | #17 |
02-01-2010, 11:06 PM | #18 |
j.Kirn; Nice dump truck! I would think that I could get a starter through napa don't you think? The tires are my bigest concern. The tires are dry rotted. Rims are bud Rh-5 Split rims the so called widow makers. What do you do there, that isn't costly.
02-02-2010, 08:40 AM | #19 |
and a few others
Most big-rig tire shops still do split rims if they have a cage. BUT, only if they're not rusty to the point of not being safe (flaking rust.)
02-02-2010, 08:46 AM | #20 |
j.kirn; meant to comment on your wheels. They look good on that truck. Have not cared for the appearance of them most generally. Do you have a pic of front of truck. bushy
02-02-2010, 12:39 AM | #21 |
you can get the starter at napa no problem easy part
02-02-2010, 09:33 AM | #22 |
02-02-2010, 09:48 AM | #23 |
J.kirn; Nice smile on the c60. Are there many people using trucks of that age around. I see a big tandem that is between 60-66, that delivers stone. Actually, I see one that is baby blue another one that is black. Both are very sharp. bushy
02-02-2010, 10:42 AM | #24 |
There are a lot of these trucks still in use some are in good shape while others are in poor condition. i also have a 1966 c-60 and several parts from other trucks
02-02-2010, 10:46 AM | #25 |
The truck in your pics looks like it might be rusted through above windshield because of cab lights are you gonna buy this truck?
