02-01-2010, 01:01 PM | #1 |
dual exhaust questions
I have a stock 72 long fleetwith a 3spd and coil spring rear. It came factory with a single exuaste. I am debating putting duals on it but only have a set of brackets on the driver side for the single.
My questions are: what are people paying for dual exuaste systems? what do you do for brakets on the passenge side? anybody run into problems using the 2 quart Fram pf 373 style filter and thier exuaste clearance? |
02-01-2010, 01:54 PM | #2 | |
Re: dual exauste questions
I ran into the same thing. No bracket on the passenger side. I used a generic exhaust hanger from NAPA. Every other part I needed for the system came in the box. My application is a 4x4 - center dump verses angle dump manifolds. You didn't say what your 72 is. The LMC 4wd kit fit around my 3-speed manual which later was swapped out for a th-350. The kit fit both. Oh and it is around $200 if I remember correctly. I don't work for LMC or Heartthrob Exhaust
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-01-2010, 04:06 PM | #3 |
I just ordered a manifold back dual set up with stock exits from Summit made by Hooker Headers for my Burb. It was $203 shipped. I'll still need to get two turbo-type mufflers which will be another $50. I'll let folks know how it fits once I receive it Wednesday. I looked at the similar offering from LMC that came with mufflers for $210 Plus shipping, but I didn't find an application for a 2wd Burb, only 4wd. I'm sure with shipping it will be at least the same.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-01-2010, 05:23 PM | #4 |
I get them built & installed at a muffler shop for $300.
02-01-2010, 05:30 PM | #5 |
Watch out for your cornhole !
240 dollars from manifolds to the bumper including the tips. No mail order system would work for my truck since it is lowered pretty far. The muffler shop guys build the hangers for the second side.
02-01-2010, 10:08 PM | #6 | |
dazed and confused
members met: redbaron69, billsbowtie,nc67 |
02-01-2010, 08:40 PM | #7 |
Keep On Keepin' On
Re: dual exhaust questions
My muffler shop charged 360 for pipe and flowmasters from the headers and dumped behind back axle...
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
02-01-2010, 09:49 PM | #8 |
paid 400 for mine. 2 1/4 from headers turned out behind rear wheels with flowmasters at muffler shop.
02-01-2010, 10:30 PM | #9 |
I have $325 in mine including headers(Hooker comps). The system was built to my specs, I did it on a Sun afternoon, when I worked in the muff shop. the headers were a buck 40, the slightly used 50's Flows were a freebe, & the old man runnin the shop was pretty easy on pipes/hangers, & the use of his shop.....the stainless tips that are poked through my rear bumper cost almost as much as 20 plus ft of pipe ,hangers ,&clamps under that old Longhorn. I went Percy alum on the collector gaskets, & opted for a set of weld rings to mate to the headers(40 bones for both pcs). figuring 85 a pop on the 3 chamb flows ,all in all, it would have been a 600 dollar shop job (headers,muffs,pipes/hangers & tips). 2 1/2" from the headers to the back ,with H pipe, & its all tucked nice ....sounds sweet crazyAL
http://community.webshots.com/user/hotrodhorn |
02-01-2010, 10:20 PM | #10 |
Brockman Mellow Tone steel packs- 22 inchers
http://www.brockmancustomparts.com/page2.html The audio is poor on that clip. They actually sound outstanding, a real raspy sound. I get compliments on them every time I drive it. I can't say that about any other muffler I have ever run.
02-01-2010, 10:28 PM | #11 |
69 Fleetside
I just ordered the Pypes Street Pro system with X-pipe from Jegs for $400 - All the youtube videos sounds awesome, we shall see if my vortec 383 sounds just as good...
02-02-2010, 01:28 AM | #12 |
2.5" from the manifolds to the back and 36" glasspacks with 2.5" cores. 290.00 at the muffler shop
02-02-2010, 06:53 AM | #13 |
I just did a swap on my 72 from single rams horn exhaust to Mr. Gasket headers with glass packs similar to highperf4x4. I have to say that I like the sound of the new exhaust much better.
But I like the price...I traded a 400 crank that I traded for something else and an old Q-jet carb for my set up. Before swap..... After swap.......
Thanks, Aaron Life is about making dreams come true, stop dreaming and make life happen. 64 GMC Project MY_YOUTUBE_VIDEOS To keep an opened mind- speculation is devine. Assumptions always lead to a dead end! |
