Old 02-02-2010, 04:21 PM   #1
VDOG
Grand PooBaa Member
VDOG's Avatar
Cam Replacement
Ok due to the fact that im short on money because of all the rain here in Cali, under my house took on water so I cant afford to work on my 350.
So im going to replace my cam on the 283 to keep it running for the time being. I will post picture as I go, if any of you see me doing something wrong or have advice jump in and let me know. Thanks
VDOG is offline   Reply With Quote
Old 02-02-2010, 06:08 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Cam Replacement
What is that lying on the #1 exhaust rocker -- and why is it there?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-02-2010, 06:21 PM   #3
allthrottle,nobottle
allthrottle,nobottle's Avatar
Re: Cam Replacement
looks like a loose bolt that is going to mess stuff up pretty bad if it gets left there?
allthrottle,nobottle is offline   Reply With Quote
Old 02-02-2010, 06:32 PM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Cam Replacement
I'm woundering if its going to be worth it ?? I ran the #'s on my motor and found it was a 283....I'm not rel happy about the power and woundering if a cam and set of vortecs would help it any???
what cam are you going to be running?? and why are you swapping??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-02-2010, 06:46 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Cam Replacement
Yes, but not just any old bolt.... it might be a stud, but what's the purpose of the flared end (at the top as it sits in the pic)?
- Mike -
RIP El Jay
Old 02-02-2010, 06:51 PM   #6
Hottrucks
Hottrucks's Avatar
Re: Cam Replacement
its the pin that was on the carb for the gas peddle
Old 02-02-2010, 07:00 PM   #7
evilways
evilways's Avatar
Re: Cam Replacement
I concur on this ever so exciting mysterious bolt.
Mark
1967 C/10 stepside lwb daily driver
1968 C/10 fleetside lwb parts truck
1971 Cheyenne Super swb project
evilways is offline   Reply With Quote
Old 02-02-2010, 08:34 PM   #8
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Cam Replacement
Thanks to all of you for your feedback. Gas peddle pin, I was wondering what it was. I placed it there for the photo. When I removed the valve cover on that side it was in the middle between two pushrods. Who knows how longs thats been in there.
Old 02-02-2010, 08:11 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Cam Replacement
Vortec heads won't work with a 283... they are based on a 4" bore 350.
Gary
Old 02-02-2010, 08:45 PM   #10
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Cam Replacement
Gary
Had thought about Vortec's last year. Thanks for the info, did not know they wont fit.
Old 02-02-2010, 08:58 PM   #11
bhoeger70
bhoeger70's Avatar
Re: Cam Replacement
If the valve centers are the same as the older heads the vortecs will work on a 283. Some people think that the intake valves will be shrouded by the cylinder wall (I dont think they are but I have no proof on that). I am running a 283 in my 67 it has 3.08 gears also.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin
67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts)
bhoeger70 is offline   Reply With Quote
Old 05-21-2010, 03:13 PM   #12
HOGDADDY
HOGDADDY's Avatar
Re: Cam Replacement
Fwiw I put 350 aluminum L98 heads on a smaller bore before (305 which is 3.736 bore) but had to use 350 head gaskets and it ran fine. 350 heads will work and I am guessing the Vortecs would work also as long as you don't add large valves.
HOGDADDY is offline   Reply With Quote
Old 05-27-2010, 12:37 PM   #13
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Cam Replacement
I'll keep that in mind. For now im going to use the LT1 engine, less the TPI for now. The TPI will be added later on when I start a complete build, I need a motor now to use my truck for home repairs, then I can tear it down and build it the way I want.
Old 02-03-2010, 06:11 PM   #14
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Re: Cam Replacement
Originally Posted by gasoline71 View Post
vortec heads won't work with a 283... They are based on a 4" bore 350.
Gary
x2
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 02-03-2010, 11:04 PM   #15
huero
1969 Short, Fleet, and Beat
huero's Avatar
Re: Cam Replacement
Here is my worthless 2 cents.
Buy an edelbrock performer cam and call it a day.
You can not make power with a 283 without doing tons of work to it. More work and $ than its worth.
A 283 is not a bad engine just dont expect it to run like a 383.
Leave the stock heads and save up for a nice set when the funds allow to put on that 350 you got.
Also, 3:08 gears are not bad. They are not 3.73 or 4.11's but they are a decent gear especially on a daily driver that does not have an overdrive transmission. Leave the 3:08's and save your hard earned cash.
Just my 2 cent's,
huero.
huero is offline   Reply With Quote
Old 02-04-2010, 01:44 PM   #16
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Cam Replacement
Thanks Huero.
I thought about the edelbrock cam but I figured it was going to run like the carb, not to impressive but will still work. Im not trying to get 1/4 mile time out this engine, just want it to perform a lil bit better than stock.
Old 02-04-2010, 02:24 PM   #17
huero
huero's Avatar
Re: Cam Replacement
The cam is a decent mild cam. Great for a daily driver.
Don't expect huge power increases with aftermarket parts when you are dealing with 283 ci's. It is just not going to happen.
If your goal is a nice daily driver a 283, perfromer cam, carb, headers, with the 3:08's is a nice combo.
You are almost there.
What transmission are you running?
Old 02-02-2010, 08:51 PM   #18
GASoline71
GASoline71's Avatar
Re: Cam Replacement
Vortech heads are great heads... but also have different angles for the 4 bolts in the center that accept the intake manifold. So you would have to get a different intake manifold to fit those heads.
283 is a 3.875" bore... so you will be a little limited finding performance cylinder heads.
Gary
Old 02-03-2010, 06:04 PM   #19
faribran
Re: Cam Replacement
i have 062 Vortecs on my 283.. it will rev with the best of em... i have 1.6 roller rockers...(i drilled out the pushrod slots).. my son has a 350 roller engine with Vortec heads... there is no comparison...his had a stock cam etc.. and was much stronger than the 283......... if the question is 'will the heads fit the 283"?, yes they will, but i cant see a great power gain over the stock small valve heads.
my son has since added a COMP cams roller with more gonads........ its crazy powerful now.
faribran is offline   Reply With Quote
Old 02-03-2010, 06:18 PM   #20
Camaro_nut2001
Re: Cam Replacement
Now that is a new one on me. Are you running a stock bore? I live to learn, lol.
Old 02-03-2010, 06:29 PM   #21
GASoline71
GASoline71's Avatar
Re: Cam Replacement
062's are 1998 truck heads... I'm curious too... how you got them to work on a bore that small.
Gary
Old 02-03-2010, 09:35 PM   #22
OhOneWS6
OhOneWS6's Avatar
Re: Cam Replacement
If you are going back with a non roller cam be sure to use oil with ZDDP. Valvoline VR1 is usually the easiest to find at the local part stores.
OhOneWS6 is offline   Reply With Quote
Old 02-05-2010, 07:06 PM   #23
umwtnt
umwtnt's Avatar
Re: Cam Replacement
Why not go on powerblock and see what they did to the 283 they rebuild on one of the horsepower/truck shows. I believe they rebuild the 283 for the 66? chevy pickup they had in the past season or two. They appeared to be happy with the power. Just a thought.
http://www.powerblocktv.com/site3/in...er-episodes?ep...
Hp2008-07 show
Good luck
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 02-06-2010, 01:49 AM   #24
huero
huero's Avatar
Re: Cam Replacement
Quick facts
http://www.carcraft.com/techarticles...evy/index.html
Old 02-06-2010, 09:47 AM   #25
Davetopay
Re: Cam Replacement
Hp2008-07 show
Good luck
I'd like to see this, but it appears you can't watch it online.
Davetopay is offline   Reply With Quote
