Old 02-03-2010, 08:24 PM   #1
kwilson512
Not getting fuel - Help please
I just bought a 87 silverado (305 tbi), long story short I was driving it today and it quit on me. I'm not mechanically inclined at all so I am asking for a lil help trouble shooting my problem but I've narrowed it down to a fuel (or lack there of) problem.
I dont have a drivers side inner fender and it was wet outside, the electronic componets on the drivers side were wet and wondering if this could be the issue, before today the truck has run fine but I have never had it out when the roads were wet.
The fuel pump is pumping fuel to the tbi, i loosened up the line and its sending the fuel, I got spark but its not firing. I can get it running with starting fluid but it dies ...any ideas?
kwilson512 is offline   Reply With Quote
Old 02-03-2010, 08:51 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Not getting fuel - Help please
The pump could have failed, or is about to fail. If you can get the fuel pressure checked, see what it is. TBI's need around 13-15 psi IRRC. Also, It could be the pressure regulator on the TBI, the fuel filter is plugged, or the return is plugged.
That's just a few things that came to mind right away..... I'm sure others will chime in.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 02-03-2010, 09:19 PM   #3
thehitchmaster
thehitchmaster's Avatar
are the injectors spraying?
http://www.gulftruckinc.com
thehitchmaster is offline   Reply With Quote
Old 02-03-2010, 10:27 PM   #4
kwilson512
Dont know if this will help any but the oil pressure guage was going haywire before it quit.
The injectors werent spraying.
Old 02-04-2010, 10:24 AM   #5
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
If your oil pressure guage was "going haywire", it's possible the moisture, or maybe something bigger, like no oil pressure caused the relay to shut down fuel. Since you are able to get it to run on starting fluid it's obvious is fuel related. But what is causing it could be a number of things. What's your oil pressure say? Do you have a garage you can push it into to let things dry out?
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 02-04-2010, 11:48 AM   #6
rfmaster
rfmaster's Avatar
This will only happen if main FP relay, which is controlled by ECM, is off. The oil pressure switch contacts are normally open (NO) when there is no oil pressure. GM put two set of contacts to keep FP operating just in case if FP relay fails for some reason. If you have oil pressure it should keep oil pressure switch contacts closed and FP will continue to operate. ECM has no oil pressure input so it will keep FP relay contacts closed even if there is no oil pressure in the engine - this is normal during initial cranking as it takes time for oil pump to build up oil pressure in the lubrication system. FP relay functionality is verified during POST sequence - it is important to make sure that elements in fuel control system operate before troubleshooting.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-03-2010, 10:57 PM   #7
raveer2000
raveer2000's Avatar
The injectors get signal from the Distributor module
1972 K5 CST. Work in progress. 408CI
1980 K10
raveer2000 is offline   Reply With Quote
Old 02-04-2010, 01:17 AM   #8
kwilson512
Thanks for the help, I still welcome any/all ideas and will begin working on it in the a.m.. Gonna try and start with the inexpensive stuff and work my way up since its a $1000 plow truck.
Old 02-04-2010, 04:03 AM   #9
rfmaster
rfmaster's Avatar
TBI system is relatively robust and can withstand harsh operating conditions, however water and electronics do not mix very well.
You'll have to perform series of checks
1) turn ignition key from on into run position, but do not attempt to start engine. The SES light in your instrument cluster should be on, blink off and turn on back to solid. At the same time fuel pump should come on for about 2-3 seconds and shut of. This is called POST during which ECM checks all sensors and controls. POST = power on system test. If there is no SES light verify that all fuses are good - blown injector or ECM power fuse will prevent engine start!
2) If you do not hear fuel pump come on during POST then either fuel pump relay (simple) or ECM ( not so good) are at fault. Fuel pump (FP) relay is mounted on the firewall - it is easy (and cheap) to replace.
All too often relay is OK but the socket has bad contacts.
The oil pressure sensing unit serves double duty - a) provides pressure indication to instrument cluster and b) provides fail safe contacts in case of FP relay failure. If FP relay failed and if you crank engine long enough the oil pressure sensor will provide DC power to fuel pump (once oil pressure builds up to about 4-6psi).
3) Ignition check - spark plug tester and see if there is spark during cranking. There are must be spark otherwise check ignition parts - distributor, coil, wires.
4) If 1-3 check out then it possible that ECM is not receiving distributor reference pulse signal (DRP) This signal tells ECM when to fire injectors. Check small 4-wire connector that plugs into distributor. Loose or moisture contaminated plug may be the cause. Verify 1-3 first and let us know.
//RF
"The Beast"
Old 02-04-2010, 10:24 AM   #10
Jim85IROC
Jim85IROC's Avatar
Originally Posted by rfmaster View Post
Stuff...
//RF
Thanks! That's a great post. Because I had a baby back in June, when my truck wouldn't run I had it towed to a trusted mechanic instead of doing it myself, and it's still there because he can't find the damned problem. As soon as it warms up I plan to go down there and work on it myself (should have done that in the first place!) and this will help me troubleshoot!
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 02-04-2010, 01:32 AM   #11
kwilson512
Old 02-08-2010, 12:53 AM   #12
kwilson512
Installed a new filter, pump/sending unit and fuel pump relay and still getting nothing....nothings changed.
Old 02-08-2010, 01:21 AM   #13
kwilson512
Anyone got a fuse box diagram for an 87?
Old 02-08-2010, 01:55 AM   #14
thrtsxchambers
thrtsxchambers's Avatar
Her is what I have for the fuse box. It should cover 80-87 c10. Hope it helps.
A - Choke
B - Fuse - Heater / Air Cond.
C - Receptacle - Accessory
D - Receptacle - Ignition ( key on power)
E - Fuse - Auxillary Heater / AC
F - Fuse - Instrument Cluster Feed (gauges)
H - Fuse - Tail Lights, Courtesy Lamps
I - Fuse - Wipers
J - Fuse - Horn
K - Receptacle - Power Accessories & other Accessories
L - Receptacle - Battery (constant power)
N - Not Used P - Fuse - Turn Signals, Reversing Lamps
R - Fuse - Fuse - Radio & TCS (Idle)
X - Receptacle - LOS
Z -Fuse - Stop (brake) Lights, Traffic Hazard Flashers
thrtsxchambers is offline   Reply With Quote
Old 02-08-2010, 02:13 AM   #15
kwilson512
Okay...the first sign of progress...I guess
I keep throwing the ECM B fuse (10amp)...any ideas?
Old 02-08-2010, 02:29 AM   #16
Desert1957
Desert1957's Avatar
I just went through this last summer on my neighbor's truck, It's an 87 like yours but with a 7.4 (454) engine. Ignition module went bad causing no reference to the ECM , so NO fuel pump. Installed a new ignition module (inside the distributor) and Fuel pump started working.
I know what your thinking, Module for no fuel pressure? , but this is how your system works.
Desert
Desert1957 is offline   Reply With Quote
Old 02-08-2010, 02:54 AM   #17
kwilson512
I appreciate the help everyone...been looking around the world wide web and still feel like there are 30 different possible causes.
A little more info about my money pit of a truck..
-I have dual tanks, the drivers side tank is not functional. the passenger side one is.
-My fuel gauge always reads full - never leaves full
-About a week ago my nephew messed with the tank selector switch...I put it back and the truck didnt want to start for a good 2-3 hours...dont know why but it was hell trying to start it.....could it be as simple as the tank selector switch?
Thanks in advance
Old 02-08-2010, 02:42 PM   #18
kwilson512
Okay switched out the tank selector switch ....same issues
It started again but seemed not to be running on all cylinders when started and blew the ecm-b fuse a couple more times...and back to square one only now I know the tank selector switch isnt the problem.
Also ...check engine light is working...I dont know enough but doesnt that mean my ecm is functional?
Brake light on too
Old 02-08-2010, 03:24 PM   #19
Jim85IROC
Jim85IROC's Avatar
My truck does the same thing when it does actually start and run... it acts like it's not on all cylinders. I've never checked the ecm fuse, though I have no reason to think that's blown.
454
TH400
My Sounddomain Page
Old 02-08-2010, 05:02 PM   #20
kwilson512
OKay...it seems to be running fine now...trouble is I didnt do anything new..I have the air filter off right now so I guess the only variable between now and two hours ago is that. Maybe the filter/housing is touching a bare wire or the wire is worn but just eyeballing it the wires seem okay. Could it be my original thought that water caused this in the first place and it took a couple days to dry out?...if so I need to get the inner fender in there asap bc there is alot of corrosion on the panel.
Old 02-08-2010, 05:18 PM   #21
Jim85IROC
Jim85IROC's Avatar
My problem had been intermittent for quite a long time too. First it ran fine most of the time, but would suddenly stall and not-restart. Then it got to where it wouldn't start most of the time. Now it almost never starts, but every so often, it'll start and run on a few cylinders.
So far, changing the plugs, wires, cap & rotor has been ineffective. Air cleaner assembly on or off doesn't make a difference.
454
TH400
My Sounddomain Page
Old 02-08-2010, 05:33 PM   #22
thrtsxchambers
I have no inner fenders in mine and have been caught in the rain before but never had a problem. The only time I had a similar problem to your was when my fuel pump was going out, changed it , no problem. But if you have a loose or frayed wire it could cause a problem.
Old 02-08-2010, 05:17 PM   #23
Jonboy
Slots go on anything!
You may want to change the oil pressure sending unit as well. In 87, it also has the oil pressure switch built in. It will be above the oil filter on the left side. If the switch has gone bad it will not trigger the fuel pump relay. You may have a short in the wire there also.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 02-10-2010, 02:14 PM   #24
383tbi
The sending unit on top of oil filter on the 87 is strictly for the gage.The switch that ties into the fuel pump relay is the one on top engine block next to distributor.
383tbi is offline   Reply With Quote
Old 02-10-2010, 12:49 AM   #25
kwilson512
Thanks to everyone that help me work through this issue, still dont know exactly what the problem was but I know where to check to troubleshoot it when it happens again. If nothing else you guys made me fix or replace alot of stuff that had been ignored by the PO.
I plowed all day today, had no problems at all out of it....Another day or two like this any my $1000 plow truck is gonna pay for itself....Thanks again.
