02-04-2010, 11:02 AM | #1 |
6 lug to 5 lug
I know there has to be a cheap way to convert my 70 gmc to a 5 lug. Can some one give me the best way to get this done?
02-04-2010, 11:15 AM | #2 |
Re: 6 lug to 5 lug
Junkyard. Find a 71/72 truck and take the complete front suspension including the power booster/MC/proportioing vale, and power steering set up while you're at it too, and rear axle, or keep your eye out for a complete frame, they're sometimes as little as a couple hundred bucks, especially for a longbed. You just need to check the rear end to make sure it's a ratio that you want. Cut up what's left of the frame, bring in your old stuff and the frame and get a good chunk of money back in scrap.
Even that route will cost some good $ to do it "right." With 40+ year old parts you should at least get new bushings, ball joints, tie rod ends, shocks, rear trailing arm bushings and panhard bushings too. Plus new pads, rubber front brake lines, maybe new rotors, new rear shoes...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-04-2010 at 11:19 AM. |
02-04-2010, 11:23 AM | #3 | |
Still livin the "dream" in '54
Re: 6 lug to 5 lug
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
02-04-2010, 01:33 PM | #4 | |
Re: 6 lug to 5 lug
If you use the ENTIRE front suspension, you need to buy everything for a 71/72 truck. If you only swap the spindles, you need the 71/72 ball joints, 71/72 OUTER tie rod ends (if you keep the 67-70 center link, you need to use 67-70 inner tie rod ends) and I think you may need the 71/72 pitman arm, but for my truck I just used the 71 steering box I got with the truck. Also, the little "tit" on the back of the spindle to stop the wheels from turning too far needs to be ground down if you use 67-70 lower control arms. The bump stops on them are different. Before taking the truck apart, count the number of times the wheel turns from center so you can slowly grind the tit down until the 71/72 spindles with the 67-70 lower control arms will turn properly from lock to lock... long story short, using the whole damn thing is way easier ...and obviously, if you buy an ECE or similar kit made for your year truck, it comes with everything to "make it work" with what you have.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-04-2010 at 01:36 PM. |
02-04-2010, 11:31 AM | #5 |
Under Construction
Re: 6 lug to 5 lug
71-72 had discs, Richard as long as you have a disc/drum proportioning valve your golden if you swap in a 71/72 xmember. to add more confusion, you could also swap in a 73-87 front xmember. for the rear you could get a 71/72 and it will bolt right in, if you dont want to mess with changing the rear, they make conversion axles that will give you the 5 lug rear...
we went the '72 route for my son's truck after speaking with Jesse on the subject..... best of luck.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 02-04-2010 at 11:35 AM. |
02-04-2010, 12:00 PM | #6 |
Re: 6 lug to 5 lug
It's just about the same as converting a C-20 over. I did my 72 suburban from 8 lug to 5 lug, and I had to find a 71-72 rear end, and 71-72 front end.
I could have saved some money if I thought about it, but at the time I didn't realize. Instead of buying a 71-72 complete front end I could have just bought the spindles, upper/lower ball joint, and the tie rod end. The only difference in going from drum to disk, as others have said is to get the brake booster, proportioning valve, and the calipers that go with them. |
02-04-2010, 12:03 PM | #7 |
Re: 6 lug to 5 lug
check your rear axle width, you might have the longer rear end. if you do you can swap axles instead of the whole rear end. (cheaper) But if you have leaf rear end you can use any rear end out a 73 and up truck I believe. as for the front end, you HAVE to change out your front brakes lines as wellas the prop valve. the threads are different
1967custom |
02-04-2010, 01:34 PM | #8 | |
Re: 6 lug to 5 lug
I never paid attention because I have a 4x4. Perhaps one of the 'old timers' on this board that have done this will chime in. FWIW, I know a crazy old guy that has two eights lugs on the rear, a six lug on one side of the front and a 5 lug on the other side of the front. And you think my truck is a mutt.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-04-2010, 06:26 PM | #9 |
Re: 6 lug to 5 lug
I did my 70. Its a coil rear. Its true there were 2 different rears in a 70 one being wider then the other. I was lucky and had a wid one. I dont know any way to tell other then pulling the axels out. I got a set of axels from a 77. They fit perfect. I dident even change seals. For the front it just so happens I used another 77. You can go the the mid 80s but they went to metric in the early in the 80s. Some will say you need the entire front end including the sadel. I used everything except the sadel. Upper and lower controll arms with ball joints, shafts and spindals. All the stering linkage. Cant remember if I used the 77 pitman arme or not. I did this about 15 years ago so its hard to remember. The only other thing is the the proporting valve from a 71 or 72. You could use a 73 and up but they have 2 ports for the front so you would have to plug one. And a master from a 71 and up but I dont think is mandatory. As for front springs you coud use what you have or go up to 87 I think. NAPA has a good web site that will give you the load range of the front springs. I just went with 73 front springs HD for a BB. almost leveld out the truck and rids firm but not harsh. Good luck.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
