Foolish Mortal
Wheel Bearings question
So I'm getting a "vibration" in the steering wheel when I drive. I took off the driver's side dust cap and looked at the bearings. There isn't a ton of grease, but it's not dry either.
My question is: How can I tell if the bearings are bad if there is no obvious damage? There's a little "play" if I put my fingers in the inner Bearing casing and move it in and out, but I don't even know if that's normal. Can anyone give me some guidance? |
Re: Wheel Bearings question
Get that wheel up in the air. Grab it at 6 o'clock and 12 o'clock and see if there is any play. If there is play, and it isn't in the a-frame bushings or ball joints, you probably need to replace those bearings.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Foolish Mortal
Hollister Road Co.
To inspect the bearing they need to come out and be cleaned. Then turn each roller andsee if it has damage. Usually you can tell buy the race. It would be mared or pitted. Mostlikely you have either an imbalance or worn front end parts. Bearings usually growl whenbad.
Get the tires balanced or rotate them front to back and see if the vibration moves.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 02-06-2010 at 04:51 PM. |
Foolish Mortal
Update: so I jacked up the wheels and did what mrein3 said. On the driver's side there is "more" play ( I can jiggle it and it's more noticeable) than on the passenger side, but the passenger side does jiggle too.
To address what DWSCR said: I would agree, except this problem was sudden and not a gradual thing. I would think that if something "wore out" I would notice a gradual problem. It sound like I should proceed with getting the bearings changed. |
Spin the wheels & listen for a growling noise. If so it's sure to have bad brgs. No dought they need to be inspected & packed but unless they are just falling apart it is probably not the cause of vibration.
Foolish Mortal
Hmm.. When I rotate the wheels, I don't hear a "grinding" noise per say-more like resistance (brake pads perhaps?) and a metal on metal scraping kind of sound...
I'm still putting my money on a tire or wheel issue. You may need to service the bearings but as others have said, I doubt that is what is causing you vibration.
Foolish Mortal
It's just that I've spent a lot of time/money into fixing up and I'm afraid if I drive it, the wheels are gonna fall off LOL!!
I'll try having the tires rotated, I suppose.... |
Foolish Mortal
So, I take it I'm just being paranoid about my truck then? I am *really* afraid of causing any damage to it that would run in the hundreds/thousands to fix (Money's tight right now) and I'm taking the approach of not driving it at all, but it's killing me cause I love that thing...
#13 | |
How often do you drive the truck? If it wasn't moved for a period of time the tires may have a flat spot.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 02-06-2010 at 06:28 PM. |
#14 | |
Foolish Mortal
Well, you may have a point about sitting for a spell. It was sitting for a while when I sorted out my previous problem (converting from externally regulated to internally regulated alternator-LOVED that fix, but I digress), and even when I started driving again, I would only drive it 2 maybe 3 days a week....AND the tires had started to go a little flat...so perhaps the tires DID start getting out of balance.... I'll start there-it's cheaper anyways, that's for sure!!! |
#15 |
Look at all your other front end parts too. Tie rod ends, idler arm, center link. If one of the ends of one of them is worn out, you'll be wandering all around.
