Old 02-07-2010, 10:57 PM   #1
miracle whip
miracle whip's Avatar
67 c10 questions about 4 link and z notching the front crossmember?
I have a c10 im building and im trying to lay frame on 22 and a buget. I just finished putting a notch in the rear of the truck but im trying to decide what kind of 4link or trailing arm setup im going to build? I notched the rear frame so tubeular rear controal arms would tuck up in the notch, i will try to post some pics. And also i was wondering if i have 22'' rims how high will the front crossmember be off the ground with 2.5 drop spindles. And if that will not lay frame then im thinking about notching the front crossmember what will i have to do to the steering box and all the linkage when i notch the crossmember? and will i have to reinforce the crossmember for a big block 454? Is there anything i should know or any other mods i have to do when i do the notch?
miracle whip is offline   Reply With Quote
Old 02-07-2010, 11:16 PM   #2
Sublvr72
Sublvr72's Avatar
Re: 67 c10 questions about 4 link and z notching the front crossmember?
looks good
Sublvr72 is offline   Reply With Quote
Old 02-08-2010, 01:30 AM   #3
firedog
firedog's Avatar
check out the suspension forum there is lots of info there also do a search you would be surprised what you will find
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 02-08-2010, 01:34 AM   #4
70jnktrk
70jnktrk's Avatar
Thumbs up Re: 67 c10 questions about 4 link and z notching the front crossmember?
Man, I like what you have done..
70jnktrk is offline   Reply With Quote
Old 02-08-2010, 01:49 AM   #5
miracle whip
Thanks alot, it was my first notch i was worried at first but it went smooth. And the funny thing is i used a sawzaw, angle grinder, 3 c clamps, a level straight edge and a welder. I clamped the steel to the frame and bent it by hand it worked out great took me 8 hours so far
Old 05-09-2014, 12:53 PM   #6
oldtinrods
oldtinrods's Avatar
Pretty much exactly the pics I was looking for. Thanks!
1970 C10 - 350/350TH
1954 Chevy
1929 Model A Roadster
http://www.oldtinrods.com
oldtinrods is offline   Reply With Quote
