02-07-2010, 11:59 PM | #1 |
HOW long until spring??
rust removal by electrolysis
Found this website that uses common house hold soap and a battery charger for rust removal . Any body ever tried it? Site claims it to be environmentally safe and easy and cheap..
http://antique-engines.com/electrol.asp
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
02-08-2010, 12:07 AM | #2 |
Re: rust removal by electrolysis
Yes. I use it allot.
02-08-2010, 12:23 AM | #3 |
A 69 camaro hood that was laying on the ground for years. Made a wooden box big enough. Soaked it over night and just pressure washed, treated the metal and painted.
02-08-2010, 12:56 AM | #4 |
60-66 Nut
Ha! I didn't know that electrolysis of H2O would remove rust from steel. I wonder if the electrolyte can contaminate the metal causing adhesion problems for the paint?
02-08-2010, 07:34 AM | #5 |
I never would of thought of that, I will be trying that ASAP.
02-08-2010, 11:30 AM | #6 |
02-08-2010, 07:04 PM | #7 |
I'm just glad to be here!
I may have to try this...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
02-08-2010, 09:35 AM | #8 |
66 C20 Long Step
I will be giving that a shot first thing this spring. When the temperature stays above freezing.
R.I.P. Oshawa, Ont. Truck Plant 1964-2009 Oshawa Truck Assembly -Pride & Dignity 1966 Chevrolet C20 Stepside 2WD LWB - Oshawa Built Truck 1972 AMC Matador 2dr 1998 Plymouth Breeze 2.4L |
02-08-2010, 09:53 AM | #9 |
1961 crewcab
now we just need a box big enough to fit a whole 60-66 cab in!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
02-08-2010, 11:17 AM | #10 |
PIMPING RIDES
now that's funny ,but true
1964 CHEVY 1/2 C/10 FLEET 1981 CHEVY 1/2 C/10 FLEET 1995 DODGE 1500 V6 FLEET EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
02-27-2010, 07:15 PM | #11 |
02-08-2010, 11:13 AM | #12 |
Kiddie swimming pools work well and the left over water is great for your lawn.
'77 GMC SWB '66 SNB (Project) Battle Ground, WA |
02-08-2010, 11:57 PM | #13 |
Great info...thanks for sharing.
02-09-2010, 03:58 AM | #14 |
Zero Albedo
I have a question: Will paint act as a resist, or does the electrolysis act under the paint?
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger |
02-09-2010, 04:57 PM | #15 | |
Be creative with your anodes because the currant travels (kinda) in the line of site. Dennis |
02-09-2010, 12:00 PM | #16 |
I am glad to see actual proof of woking on larger parts. The demos I have seen have been on small parts. Good info, I will have to try this process.
02-10-2010, 07:18 AM | #17 |
UCA63
But where to find a charger these days that doesn;t have the short out safety built into it,I tried it with a new one and I figured that's why it didn't work
Also I have read 2 amps maximum and on another write up I read 6-10 amps?? T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
02-10-2010, 10:43 AM | #18 | |
Senior Car Nut
I, too, have read conflicting discussions as to the amps needed, I just let my battery charger decide.
Larry Last edited by fleetsidelarry; 02-10-2010 at 11:01 AM. Reason: confused anode and cathode |
02-11-2010, 08:07 AM | #19 |
UCA63
Thanks Larry
I'm going to give it another try T
02-12-2010, 01:07 AM | #20 |
Clamps can be in the water. Wont short out, but they will corrode over time. I use a pair of vice grips and clamp to the part. leave part of the handle stick out of the water and clamp your charger to that. Just dont let your part that your derusting touch the anode steel or it will piss off your charger and your wallet.
02-12-2010, 11:16 AM | #21 |
I did this with a set of cast iron exhaust manifolds recently, turned out great! One trick is to have multiple anodes all wired up together surrounding the part. That takes care of the "line of sight" issue by having multiple lines of sight! Similar to what this guy did.
I let my charger run at the minimum setting, 2 amps, and it worked fine.
www.vancerutherford.com |
02-25-2010, 06:29 PM | #22 |
Maybe someone can help me with what went wrong. I am using a 25 gallon vinyl cotainer. Made 4 electrodes out of rebar, cleaned them and placed them around the inside of the barrel. Used washing soda, 1/2 cup per 5 gallons. Connected all my electrodes in series with wire. Lowered the hood springs careful not to touch the electrodes or bottom of barrel. Hooked up the pos to the electrodes and neg to the hood spring and turned on the charger. I read where I should see bubbles forming on the hood spring, well that did not happen. I could not visibly see any action on the part. Is my charger set at 12volts at 15 amps too small for my 25 gallon tank? Or did I do something wrong?
" I never think of the future. It comes soon enough " - Albert Einstein Last edited by Muleman100; 02-25-2010 at 06:30 PM. |
02-25-2010, 09:03 PM | #23 | |
Senior Car Nut
Your battery charger is definitely big enough, you only need a couple of amps for this to work
Larry Last edited by fleetsidelarry; 02-25-2010 at 09:07 PM. |
04-01-2010, 11:21 PM | #24 |
I use an old Hobart TIG/AC/DC welder as a power supply in my 55 gallon plastic barrell... Works very well and you can adjust the current to whatever works best for you... I like 8 amps personally, and have done many parts ove rthe years...love it!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
02-25-2010, 09:37 PM | #25 |
Great info - Thanks
