Old 02-08-2010, 03:32 PM   #1
bbadfred
bbadfred
bbadfred's Avatar
Lq9 stock intake tube
Does anyone know what the apendage on the underside of my lq9 intake tube is for? My gm mechanic friend thinkes its to supress intake air noise? I want to remove it but won't if it will hinder performance.
bbadfred is offline   Reply With Quote
Old 02-08-2010, 03:42 PM   #2
6772owner
Gearhead
6772owner's Avatar
Re: Lq9 stock intake tube
Im not 100% sure, but I would agree with him, I think its just a silencer chamber to curb intake noise. All the aftermarket intake systems eliminate this "chamber" and use a straight flow tube whenever possible. I would just purchase the Airaid MIT for the vehicle you need and go for it, or you can just make your own tube.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 02-08-2010, 03:48 PM   #3
bbadfred
bbadfred
bbadfred's Avatar
I am using the stock intake tube to clear the stock clutch fan and hoses.
Old 02-08-2010, 03:59 PM   #4
ls1nova71
ls1nova71's Avatar
It's just for noise cancellation, you can cut it off without causing any performance issues, but you will probably find out that nothing is going to stick to the plastic that the tube is made of, so patching the hole won't be as easy as you might think. Personally, I'd leave it, you can hardly see it on my truck, or do as suggested and get an aftermarket one.
ls1nova71 is offline   Reply With Quote
Old 02-08-2010, 04:12 PM   #5
bbadfred
bbadfred
bbadfred's Avatar
Thanks guys! this is the greatest forum on the internet where a person can get answers for most everything!!! I am going to look into aftermaket, is there one made with the flat area on it? I have a friend with a plastic welder who said no problem welding it.
Old 02-08-2010, 04:35 PM   #6
bbadfred
bbadfred
bbadfred's Avatar
Just looked up the Airaid mit tubing and that could work also. Thanks again for the responses. I did not know about Airaid!
Old 02-09-2010, 01:16 PM   #7
6772owner
Gearhead
6772owner's Avatar
I would leave the stock arrangement from my experience as well, I have had my fair share of problems with non-factory electric fan set-ups, and (IMO) they CANNOT pull the same CFM that an engine driven fan can pull. The Airaid stuff is very high quality and I used to sell the crap out of it at my previous job, you wont be disappointed.
Old 02-09-2010, 02:07 PM   #8
Clyde65
Clyde65's Avatar
I used my stock radiator on my ls swap and purchased a 95-98 v6 f**d contour Mur***y mistique dual fan ( new $100, used $30.), a dual fan controller (Torqflo # 733647 ( orielly $35.00). the dual fan will pull 3400cfm, better than most electric and all mechanical fans that I am aware of, and no hp robbing.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-09-2010, 02:46 PM   #9
eagleuh1
eagleuh1's Avatar
Sorry to hijack, but where can you get this fan new for $100. Thanks. And I used the tubing from intaketubing.com also for my 5.3 conversion.
eagleuh1 is offline   Reply With Quote
