02-09-2010, 01:48 PM | #1 |
Any tips on installing vent window rubber?
I bought new vent window rubber for my '71.
Last night i started on one of them. It took me quite a while to get both sides of the "foot" down in the channel. I sprayed some silicone down in around everything and I still had a lot of trouble. I still don't think i got it down in the front corner like it should be. Is there some sort of trick to this or is it just going to be a pain? |
02-09-2010, 01:59 PM | #2 |
Re: Any tips on installing vent window rubber?
subscribe, Ill be doing this too
1967custom |
02-09-2010, 02:05 PM | #3 |
02-09-2010, 05:11 PM | #4 |
I had the same problem so i slightly pryed the channel apart so it would go in slightly easier and in the sharp corner i cut some of the rubber off so it would go in. It may not be the right way but that is how i did mine and the rubber is in there good and tight and i crimped the channel back some. hope that helps
02-09-2010, 06:56 PM | #5 |
I just did this. I had to take the frame apart and rivet it together again . When I put the new rubber in I used dish soap as a lubricant. It's very slippery, and then washes off easily.
1971 C10 Longbed, 350/TH350 |
02-09-2010, 07:20 PM | #6 |
Here is a revit tool we sell and also rent to install the revits
http://www.bumpandgrindgarage.com/New_Listings.html Its a bit pricey to do just a couple windows thats why we rent it also. This is the best tool made to install the revits quick We sell the revits and setting tape as well. |
