03-25-2002, 12:42 AM | #1 |
Carb and intake instalation ??
Well, I just bought a Holley # 4175 carb with a electric choke from ebay. As soon as I can get a few more things together, I will instal the carb along with a Edelbrock Performer Intake manifold and a HEI distributor. Right now the only question I have is where to hook the wires from the choke and the distributor. I am sure I will have more questions later, but if anyone has any advice now I would appreciate it.
------------------ 1970 C/10 Light Red 350/350 Dual Exhaust w/Flowmaster 40s
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
03-25-2002, 01:03 AM | #2 |
Strongman Garage
for the HEI run a 10 or 12 gauge wire from the "batt" terminal to the "ign unfused" port on the fuse panel
------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
03-25-2002, 07:14 AM | #3 |
The electric choke wire needs to come off a ignition "ON" hot wire from the fuse box. I believe the HEI wire should come off the solenoid to the distributor. That way you'll get the 12 plus volts to run in properly.
Fayette Alabama |
03-25-2002, 08:45 AM | #4 |
The HEI wire needs to run to Ign unfused in the fuse box. The yellow wire at the soleniod only provdes 12 volts while the starter is cranking. Also the yellow & white wires can be clipped out of the system.....69 longhorn.
http://community.webshots.com/user/hotrodhorn |
