02-10-2010, 08:34 PM | #1 |
T56 into a classic
Here's some info and pics for anyone wanting to use a T56 and original clutch. The trans is from a 96 LT1 Camero. A LS1 input shaft is to go into the T56 because this conversion require a longer input. All part thur far have been purchased from thegearbox.org
02-10-2010, 09:19 PM | #2 |
Grandpa in the rustmobile...
Re: T56 into a classic
what is the t56 5spd or 6 spd? Whats the cost on these bad boys?...how does the shifter fit in the cab close to bench seat just perfect?..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-10-2010, 09:24 PM | #3 |
6-speed : ) the shifter is too far back but thegearbox sells the hardware to put the shifter in the middle of the transmission. I paid 800 for the trans and a touch over 400 for the kit, input shaft, and longer pilot bearing.
02-10-2010, 09:57 PM | #4 |
How hard is the swap? what do you do about the clutch...me likey this
02-10-2010, 11:13 PM | #5 |
Well so far so good, I'm in the middle of it. Apparently the clutch stays the same with the exception of having to get a disc with 26 spline
02-11-2010, 08:27 AM | #6 |
What set up did you have before the t-56?
I thougth these trannys required hydraulic clutch setup. keep this updated with pics of the install and any issues that you run into. this swap is on my list. i just need to locate a T-56 |
02-11-2010, 10:47 AM | #7 |
Hmmm so its a FAIRLY easy swap, when your done if ya done mind put a parts list and how much it $ with pics lol thanks keep going good luck and yeah wat'd ya start with 3ott auto 4sp
02-11-2010, 11:05 AM | #8 |
I am interested seeing this too. Also, what was your solution for the tranny crossmember? |
02-11-2010, 11:13 AM | #9 |
I didn't start with anything because I bought this frame bare. It didn't have the provision for the Z bar mount so I'm guessing it was an auto. My "original" hardware came from my old long bed frame which was a 3ott, then a Muncie. I was head down the route of a 700r4 until my friend called with this trans offer. My trans member is the crossmember from Nathan Porter.
02-11-2010, 04:40 PM | #10 |
On the path to financial ruin!
Sweet swap. I see you have an adapter plate there. So, you must be running it behind a 1st gen block. Guys, this is an easy swap. A list of thing you have to do is as follows. Nothing that a fab guy or some of you with welding skills can't do.
1. Tranny tunnel modification (raising it up with a high hump) 2. Tranny crossmember modification ( moving it back a few inches) 3. Driveshaft shortening 4. Clutch pedal setup 5. Hydraulic set up (for LS Gen 3's or adapter plates for SB/BB)
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
02-11-2010, 05:19 PM | #11 | |
4. Don't need a new clutch set up 5. Keep the original Z bar Last edited by dan468; 02-11-2010 at 06:18 PM. Reason: make it correct |
02-11-2010, 07:38 PM | #12 |
Been wondering how this was done while keeping the stock clutch linkages. Thanks for the info, I got a new bookmark
Where did you find your tranny? |
02-11-2010, 07:45 PM | #13 |
My buddy is putting a built auto into his 1996 Camero and called me to see if I knew anyone that wanted his 6-speed. Of course I knew someone, hard to pass up
02-13-2010, 09:48 PM | #14 |
Cut off the front nose today to allow room for the adapter plate...
02-23-2010, 03:14 PM | #15 |
I would like to talk with the people that has done the t 56 into the truck thing as I am really thinking about doing this. Please mail me at twilliams@midconcables.com
Thanks |
03-13-2010, 10:48 PM | #16 |
sorry about the delay, the shop can't polish it with all the guts still in, too heavy.
I guess now's a good time to put in the mid shift kit. Last edited by dan468; 03-13-2010 at 10:48 PM. |
03-15-2010, 10:36 AM | #17 |
I am also interested in moving my shifter forward on the trans also. So I will keep watching this thread as it will be something I intend on doing very soon.
03-15-2010, 11:01 AM | #18 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=300892 |
03-15-2010, 11:10 AM | #19 |
Thanks Dan I have already found this thread and have a printed me a copy out for a reference for the future. I have no idea at this point when I will convert mine as I have decided to do all the upgrades at onece. Which will include but may not be limited to the T-56 from a turbo 350, drop spindles with disk brakes on the front, Vintage ac package, 18 circuit Painless wiring harness, insulate and sound proofing the cab, replace a major seal in the front of the cab. it leaks when driving in the rain. I have not done this type of work in a very long time so I am sure it will take me a lot of time to complete this one.
03-30-2010, 03:22 AM | #20 |
Getting closer... |
03-30-2010, 08:11 AM | #21 |
Dan that sure is a pretty t-56 I still have not started mine yet but I am rounding up parts for the conversion though. It never seems to go as planned though and if it did I think it would scare me. I did find out the any 27 spline turbo 350 yoke, powerglide and most manual yokes will work on the T-56 though.
03-30-2010, 04:47 PM | #22 |
im doing the same swap but with an ls1 and bucket seats and i had to buy the mid plate for the ls t56 to convert my lt series t56 to work along with the longer input shaft. also u can buy alot of the same parts from ddtransmissions.com . its still a sweet swap let me know how the hydraulic setup works out
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted 1997 C3500 DRW Ext cab. 454, 4L80E daily driver |
03-30-2010, 09:25 PM | #23 | |
05-19-2010, 05:33 PM | #24 | |
Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
05-19-2010, 07:41 PM | #25 |
Pretty easy it only took a day. I've never taken a transmission apart before (I took everything apart as opposed to leaving it mostly together because I had it polished) and it was very straight forward. I was surprised at how easy it was. I am keeping the factory clutch hardware and not using hydraulic.
