Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-11-2010, 07:05 PM   #1
iceman3085
iceman3085's Avatar
which spool do i need
im going to put a spool in the truck and need to know which one i need , truck has a narrowed 12bolt, with 6 lug axles they should be 31 splines correct?
iceman3085 is offline   Reply With Quote
Old 02-12-2010, 12:58 AM   #2
shortbed70
shortbed70's Avatar
Re: which spool do i need
Im betting 30
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 02-12-2010, 11:51 AM   #3
nxtruck
nxtruck's Avatar
If it's the factory truck 12-bolt, it'll have 30-spline axles. If you're going to a spool, you should consider a good set of axles anyway. Something else you're going to need is a set of c-clip eliminators; that is, if you end up putting a spool in it.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 02-13-2010, 04:35 AM   #4
71chevytruckguy
71chevytruckguy's Avatar
You must have c-clip elimators to put a full spool in it and to put c-clip elimators in u must get aftermarket axles. 33 spline should do ya good assuming your making under 700ish hp. You can run a mini spool with stock axles but I wouldn't reccomd it all unless you think going down the track on 3 wheels is fun, been there done that. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 02-14-2010, 09:24 PM   #5
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
I would go with the Mosier spool and axle package its very affordable.
They give you options of lug pattern, stud sizes and axle spline sizes
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
