Old 02-13-2010, 12:14 AM   #1
1moretoy
how low can i go?
i have a 70 short fleet wood bed with a cpp c-notch, and wanted to know if it would be worth the work raising the floor to get full use of the notch. how low can i go without raising the floor. anyone have pics with bags, c-notch, 20's and stock height floor. thank you
1moretoy is offline   Reply With Quote
Old 02-13-2010, 07:36 PM   #2
1moretoy
Re: how low can i go?
ttt
Old 02-13-2010, 07:38 PM   #3
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Might try using the search function. I believe this question has been asked numerous times.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 02-13-2010, 09:09 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I'm at 5.5"/7.5" static drop on my '69 swb.
Old 02-13-2010, 10:33 PM   #5
1971gmcshortbed
1971gmcshortbed's Avatar
How did you get that static lolife? That is exactly where I want to be, I have a 71 1/2 ton with 3" spindle, 1" spring, 4" leaf and 1.5" shackle, (disassembled). I may need to re-do this thing.
1971gmcshortbed is offline   Reply With Quote
Old 02-13-2010, 10:46 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Here's the build thread:
http://67-72chevytrucks.com/vboard/s...hlight=no-life
And the suspension is made up of:
'71-72 drop spindles
3" springs (front)
6" springs (rear)
1.5" lowering blocks
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-14-2010, 12:02 AM   #7
lolife99
lolife99's Avatar
Mine is a coil spring rear truck.
front:
2.5 spindle
3" drop spring
rear:
6" drop spring
1.5" lowering block
You might need stock rear leaf springs and a flip kit to get the back this low.
(and maybe a lowering block)
You can always trim your front coil springs to lower the front a little more.
Old 02-14-2010, 09:32 AM   #8
DZL1
One day.....
DZL1's Avatar
Heres mine. Bagged with a bolt on CPP notch on 15" rallies. Stock bed floor.
DZL1.
DZL1 is offline   Reply With Quote
Old 02-14-2010, 12:20 PM   #9
1moretoy
dzl1 are you maxed out on the notch or do you have a bigger bump stop so you dont hit the bed floor
Old 02-14-2010, 12:46 PM   #10
hchad18
hchad18's Avatar
You would need bags and 2" blocks to have to utilize the whole notch. You would also have to cut out a small section of the cross member above the differential because the nose of the diff will hit it, and then you'll only gain an inch. This requires raising the floor. If I had to do it again I wouldn't. If I were going to do this much work you might as well try to lay frame. This is my experience with the weld in arch notches.
hchad18 is offline   Reply With Quote
Old 02-14-2010, 05:53 PM   #11
DZL1
One day.....
DZL1's Avatar
I have the bump stops that come with the cpp notch kit. My pumpkin comes close but doesnt hit the bed.
DZL1.
Old 02-13-2010, 10:49 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
IMO... bags will be as low as you can go with only a standard notch in the frame. As far as how 'low' that will be, that will depend on the wheel/tire specs.
If you only go with a static drop, a 4.5/6" drop will be as low as I would go in order to run 20's; unless the specs were spot on and accounted for turning radius and suspension travel, you might be able to go a tad lower, but not without notching the rear as you have done.
For the specs you mentioned above, any standard bag system will allow you to lower the truck as far as possible without major modification.
-Nate
Old 02-14-2010, 01:39 PM   #13
Ackattack
Ackattack's Avatar
This is about as low as you can go, the pumpkin is within about 1/8" from the bed floor when it's sitting on the airbag bumpstops. I also have some block too.
Ackattack is offline   Reply With Quote
Old 02-14-2010, 04:22 PM   #14
1971gmcshortbed
Lots of good info here, and some very sweet trucks, I do have more questions. With only a cpp notch (no dropmember) what will hit first? Pumpkin on bed, driveshaft on crossmember or axle on notch? Given that there are no bumpstops. Some one should know this...
Old 02-14-2010, 04:55 PM   #15
lolife99
lolife99's Avatar
With a 2" block,... I would say "pumpkin hits the floor".
Old 02-14-2010, 05:02 PM   #16
avysittinon22s
avysittinon22s's Avatar
mine was either the floor or the crossmember
avysittinon22s is offline   Reply With Quote
Old 02-14-2010, 09:51 PM   #17
jsmithbm
jsmithbm's Avatar
crazy question i know but what does static mean?
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 02-14-2010, 11:06 PM   #18
BossHogg69
motor exploder
BossHogg69's Avatar
static is a drop with regular coil or leaf springs - i.e. non adjustable.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
