02-13-2010, 07:32 PM | #1 |
Dan
WTB: Crankshaft Pulley
Hi guys, i am in need of a double groove crank pulley for a small block. Need it for my power steering conversion. If anyone has one, please give me a price, and diameter. a picture would be nice too. Thanks! Dan.
1968 C10 Short Fleet - L79 327, th350 1971 Nova - 327, Th350, 3.73 posi 1971 K10 Short fleet - 350/350 1971 K20 longbox - 350, 4spd 1970 Chevelle, Tunnel ram set up 355, th350 1986 C30 Dually, 454/400 1967 Impala 4 door hardtop, Supernatural clone 1968 Camaro, 327, pwerglide 1967 camaro, numbers match 350, powerglide, bench seat car 1968 Nova, Numbers match 6cyl, powerglide 1968 Nova, 327, th350 1970 Impala, 350, Th350 1968 Impala, Numbers match 350, Th350 1971 Chevelle SS, Numbers match 350, muncie |
02-13-2010, 10:45 PM | #2 |
never finish start another
Re: WTB: Crankshaft Pulley
try this 270531185148 on ebay I needed the same thing. I bought one for about the same price. Mine came a little cleaner but they are cast iron and will look just fine with a wire brush and spray paint. Hope this helps. works perfect with the double groove pulley on the front. gives you 4 grooves the third will match the pump pulley.
02-13-2010, 11:31 PM | #3 |
Dan
hmm im not sure now. if i added that pulley you showed me to a single groove would it work?
02-14-2010, 12:04 AM | #4 |
I have a double grove crank pulley if you are interested. Its the same as the single grove but is of coarse two groved. If you are interested I'll get you a pic in the morning.
02-14-2010, 12:06 AM | #5 |
Thats Groove its getting late
02-14-2010, 12:33 AM | #6 |
Dan
Thanks for your help guys, im going with one on ebay
02-14-2010, 06:19 PM | #7 |
The one on ebay will work. If you have a single on now you will end up with a gap between the two pulleys but it will still work.
02-14-2010, 06:38 PM | #8 |
Dan
Thanks nplocoman, will i need longer bolts? if i remember correctly they are pretty short bolts
02-15-2010, 06:28 PM | #9 |
Yes, you will need longer bolts by 1/2 inch. They are 3/8ths fine thread.
02-15-2010, 06:48 PM | #10 |
Dan
Thanks again nplocoman!
02-15-2010, 07:15 PM | #11 |
If you don't have them out yet, just get some 1 inchX 3/8ths with lock washers. Fine thread!
