Old 02-15-2010, 02:33 PM   #1
memphismade.l.a.w
memphismade.l.a.w's Avatar
Exclamation how much is this worth
its a 69 c10 not put together trans engine wireng harness not in im looking in to buying it it is a swb only rust he says is in rocker panles what would yall pay?
memphismade.l.a.w is offline   Reply With Quote
Old 02-15-2010, 02:57 PM   #2
71 super
71 super's Avatar
Re: how much is this worth
No more than $400(prob. less) depending on what comes with it. You will have a lot just fixxing what he has messed up already.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-15-2010, 02:59 PM   #3
johnechi
johnechi's Avatar
$200 bucks. The boat anchor is a buick engine.
johnechi is offline   Reply With Quote
Old 02-15-2010, 03:02 PM   #4
big_al_71
big_al_71's Avatar
I would say $500.00 at best..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-15-2010, 03:04 PM   #5
memphismade.l.a.w
he said its a 455 rocket motor idk what that is at all
Old 02-15-2010, 04:05 PM   #6
OhOneWS6
OhOneWS6's Avatar
I doubt that is an olds 455 rocket. That blue is the later model color Olds used. Rockets were gold. Sure someone could have painted it but I'm putting money on it being a plain old low compression Olds motor from the late 70s early 80s. It will not be worth much so don't count or recouping much from that motor.
Here is a site with tons of Olds info.
http://www.realoldspower.com/phpBB2/index.php
OhOneWS6 is offline   Reply With Quote
Old 02-15-2010, 04:21 PM   #7
lks dcvn
lks dcvn's Avatar
Your best bet - is to find somebody local to it and have them go check it out - I am guessing that there is more than just rust in the rockers - this may save you a LOT of time and money.
Just a thought - although for $400 - I might take my chances...
lks dcvn is offline   Reply With Quote
Old 02-15-2010, 03:08 PM   #8
memphismade.l.a.w
ok did some research its an olds motor
Old 02-15-2010, 03:16 PM   #9
too much stuff
Roadtrip!
too much stuff's Avatar
I would say $500 would be pushing it.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-15-2010, 03:22 PM   #10
memphismade.l.a.w
he said hed take 400 its a craigslist find im in memphis so ill have to drive to get it
http://memphis.craigslist.org/cto/1569030255.html
Old 02-15-2010, 03:33 PM   #11
too much stuff
Roadtrip!
You will probably be ok at $400. Dump the engine and recoup some money and tear into a major project it looks like. It is a shortbed, thats the good thing. Let us know what happens...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 02-16-2010, 11:19 AM   #12
pumpkin
pumpkin's Avatar
your research is wrong. That is a buick engine. Cant tell what size from the front as all buick engines look very similar from that angle. Chev, olds, and pontiac have the distributor in the back. Buick, cadilac and fords have the distributor in the front. As far as the value of the truck, I would put it at whatever the box is worth. Anyone that would drop a buick engine between the framerails, and walk away from the project, has probably hacked the rest of the truck as well.
pumpkin is offline   Reply With Quote
Old 02-16-2010, 11:46 AM   #13
OhOneWS6
OhOneWS6's Avatar
I agree about the Buick engine. I noticed that at first but I didn't think that cap was on the distributor. It looked like it is just sitting there.
Old 02-16-2010, 01:26 PM   #14
memphismade.l.a.w
Ill have to tell the guy this
Old 02-16-2010, 03:26 PM   #15
83Silverado
83Silverado's Avatar
I couldn't tell you what it was
83Silverado is offline   Reply With Quote
Old 02-15-2010, 04:39 PM   #16
83Silverado
I'm always looking on craigslist and other sites to, I will keep an eye out for you something
Old 02-15-2010, 05:16 PM   #17
69GMCLonghorn
69GMCLonghorn's Avatar
Yeah, that thing didn't just get dumped in that field. I'm thinking lots of surface rust, brake lines are probably shot, U-joints can't be good, etc. etc. You're looking at a ground up resto to whatever extent your wallet and abilities allow. Unless you're loaded (money wise) and have TONS of time on your hands, I'd look into spending maybe $2000 and get yourself something that is the model you want and actually runs. Once you do that, if you need a parts vehicle, THEN buy this lump of crap and have a field day!
69GMCLonghorn is offline   Reply With Quote
Old 02-15-2010, 07:23 PM   #18
weircc
weircc's Avatar
yea what he said don't get something your gonna lose interest before you get started.
weircc is offline   Reply With Quote
Old 02-15-2010, 08:06 PM   #19
too much stuff
Roadtrip!
Seeing your age, i assume you have more time than money. See if the owner would take $200 and keep the engine. I wouldn't think you would want to use it anyhow. Maybe you can settle at $250-$300. I would look it over good for rust and make sure it isn't packed full of mud. Paint jobs like that spook me sometimes. If it is fairly clean you can't hardly loose at this point. Just don't get excited and jump into just because you want a truck. There are more out there if you don't like something about this one.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 02-15-2010, 08:40 PM   #20
71cheyenne4x4
I don't think $400 is a bad at all if it has a clear title and is solid. If it really is a 455 you could sell that for almost what you paid for the truck and not have much in the truck at all.
71cheyenne4x4 is offline   Reply With Quote
Old 02-15-2010, 10:32 PM   #21
landon4421
Life is Good !
landon4421's Avatar
Purple
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 02-15-2010, 05:28 PM   #22
83Silverado
Yeah im about to to spend $7k for a nice restored '71 truck that just needs a few odds and ends but all the headache is done already. I once tried to start with a truck like this and was going to be WAY more tha what im about to spend but well see
Old 02-15-2010, 06:44 PM   #23
Blue71LWB
Blue71LWB's Avatar
See if he would be willing to sell the bed off of it, and leave the rest where it sits.
Working on my first 1,000 post.
I'm sure I'll get there before this project is over .
Blue71LWB is offline   Reply With Quote
Old 02-15-2010, 07:09 PM   #24
memphismade.l.a.w
well im 16 so idk how much i can afford to do should i try talking down less you guys think and saying that its not a 455 in it
Old 02-16-2010, 03:36 PM   #25
Blue71LWB
Blue71LWB's Avatar
If this is the case, run away from this one as fast as you can. If you can hold out, you should be able to find one around $1,000 that you could at least drive around while you fix it up. If you sunk $1,000 into this jewel it still wouldn't be able to see the road. It's worth $400 , but it sounds like you need some wheels ,and if this is the case, I do not think its a good deal. This one is not worth the gas to go look at it. JMO
