![]() Join Date: Jul 2009
removing the bed
I was wondering if there's an easy way to remove the bed using a cherry picker? I don't have anyone that can help me remove my bed but I do have a cherry picker so I was wondering if anyone has fabbed up an adapter to make bed removal a 1 to 2 person job.
Re: removing the bed
Stacey David used this one when he was playing with copperhead (http://truck-bed-lifter.brutmfg.com/) . As you can see from the photo it's not too hard to weld one up from square tubing.
![]() Which is what I did as I work alone. |
![]() Join Date: Feb 2007
CB24 just type in one man cab and bed lift into the search feature. It should pull up Rokcrln from LFD who sells the prints to make an adjustable bracket to use on your cherry picker.
68'chevy swb 350/200r4 71’ chevy swb 6.0/4l80e |
Contact Rokcrln, like stated above. www.lewisfabricationdesign.com for plans. I built mine and use it all of the time. Great for cab and bed removal.
Thanks guys! I knew it was somewhere on here but couldn't remember where I saw it.
#6 | |
I used a 4x4 (or a couple 2x4s) in the middle, tucked under the bedrails, balancing the bed.
I had it on and off at least four times during this latest redo. K Quote:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-16-2010 at 05:04 PM. |
I also made a little stand out of some scrap wood, to support the bed during transportation and the painting process:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-16-2010 at 05:15 PM. |
Not bad keith! Thanks for sharing your ideas.
Moderator
![]() Join Date: May 2007
Two people can do it. Unbolt the bed, slide it backwards a little, then tilt it onto the ground up-ended, then carefully keep turning so it ends up upside down. The top of the bedsides support the weight easily.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 02-16-2010 at 05:09 PM. |
