02-18-2010, 04:17 PM | #1 |
Poll: Is your frame too high for your rolling floor jack?
Just wondering if I am the only one with this "fun" problem.
02-18-2010, 07:04 PM | #2 |
Re: Poll: Is your frame too high for your rolling floor jack?
lucky if I could lift the tires off the concrete when placed under the diff, let alone the frame
02-18-2010, 07:05 PM | #3 |
Another Day, Another Dollar
yeah, whats wrong with just lifting by the axle housing?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
02-18-2010, 07:18 PM | #4 |
he might need to swap an axle, but even then he could jack up by the axle and then put jack stands under the frame. So back to willet's question.
And there's no poll.
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 Last edited by onlyifihadachevy; 02-18-2010 at 07:19 PM. |
02-18-2010, 07:21 PM | #5 |
I lift by the axles,then place the stands under the frame when doing work that requires the axles free.I use a 4x4 or 6x6 block of wood when needed.You can lift the axles,remove tires,let down drum and rotors down onto wood,the lift the frame from a lower point thsn stock.
02-19-2010, 08:59 AM | #6 |
I lift by the axle and even then I can barely get the tires off of the ground and 6 ton stands fully extended barely reach the frame
1949 Five Window, 1973 Step Side, 2000 Z71 |
02-19-2010, 10:54 AM | #7 |
I generally take 6 or 8 pieces of 3/4" boards cut about 14" x 14" and stack them, then put my jack stands on them, otherwise my jack stands don't reach the frame. You can kind of see what I'm talking about in this pic
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
02-19-2010, 11:15 AM | #8 |
The only time I don't need a wood block is if I'm jacking up using the bottom of the diff otherwise wood is needed.
12Ton jackstands are what I use to hold the frame/body when I drop out an axel Otherwise like YJ w/5Ton you need to raiseum up w/wood.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
02-19-2010, 11:59 AM | #9 |
um ! ... they sell biggger floor jacks
02-19-2010, 09:49 PM | #10 |
I never saw it as a hassle jacking any of the lifted trucks Ive had since`77.If I saw it as a hassle I know the solution...I wouldn`t lift a truck.A stock 4wd isn`t exactly much different.
02-20-2010, 08:10 AM | #11 |
02-23-2010, 05:12 PM | #12 |
hahaha Well, gotta give you an A for effort
02-20-2010, 09:08 AM | #13 |
Cheif Liftumup say:
"You lift`um truck,you get`um bigger jack" "No get`um bigger jack,go get`um block of wood" "Block of wood not biggum enough,gettum bigger wood" "Use`um head.Jack`um up by axles.Take`um of big`um tires.Let`um back down so jack`um stand work" What I`ve found is there`s no need to jack a truck up unless you`re removing tires(lift axles) or a rare axle removal.Then I lift,take tires off,let down lower on short stands,lift truck off axles,support with big stands,put jack under axle,lift enough to pull stands,roll axle out...not any pain at all.Pretty much how any axle swap would go.You definaitely need bigger stands than the standard car ones.I have two big and two small.I`d like to double that up to be equipped for whatever.
02-22-2010, 10:51 PM | #14 |
too tall for cheap jack stands and 7' garage doors..you would think these homebuilders, who drive trucks, would help a brother out..
02-22-2010, 11:24 PM | #15 |
I`m a builder and will give any size door you want to pay for.The standard is 7' and attached garages are traditionally intended for cars.Trucks belong outside or in real garages with real doors.Most house elevations limit what height can be used.Mos don`t wan`t a large door for they detract from aesthetics.
02-22-2010, 11:48 PM | #16 |
Kid's Mechanic
On my mudder my floor jack wont even think about the frame.
Its under the axle and two 5 ton jack stands on 2 two foot long oak 12"X12s" Last edited by powerdriver 1958; 02-22-2010 at 11:57 PM. |
02-23-2010, 12:02 AM | #17 |
Currently Blazerless
I have a pair of 7 ton Gray air operated end lifts, used together I can raise a truck 5 feet off the ground. Also have a Gray air lay down jack that is good for using under a differential to lift up to 3 ft. If my ceilings were high enough I would love to have a 4 post lift.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
02-23-2010, 02:37 PM | #18 | |
02-23-2010, 12:42 PM | #19 |
the pollock
i have to use pallets i made for my jackstands out of 2x4's and i have to make a ramp for m jack to be able to fully lift the front tires..
i did my axle swap with my tires maby two inches off the ground.. BUT i did it sitting straight up under the truck no problem
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
02-23-2010, 01:10 PM | #20 |
Chain fall
Look closely and you can see the chain around the rear frame. Axles not mounted http://i99.photobucket.com/albums/l2...c/IMG_1083.jpg |
02-23-2010, 05:56 PM | #21 |
no way....this is fun.....I was going to add that last week I used 2 logs from the firewood pile.
02-23-2010, 06:23 PM | #22 |
Log Splitter
02-23-2010, 08:19 PM | #23 |
Redefining LowBudget
I can even figure out how to get it under the frame sorry guys I had too...lmao
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
02-23-2010, 10:30 PM | #24 |
ha, yea same boat here. I have to get someone to lift up on the front end to get it under.
1969 Chevrolet SWB Stepside 1959 Chevrolet apache * Sold 1967 Prostreet Chevy SWB Fleetside *Sold 2014 1/2 ton Crew Cab Chevrolet 4x4 |
02-24-2010, 12:33 AM | #25 |
Grease Monkey
Here is my "jack stands"
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
