02-18-2010, 10:43 PM | #1 |
Lowering shackles?
I want to lower my truck some. And flipping the rear end would be way too much for me. So I think shackles is the way to go for me. Anyone want to point me in the direction of some good ones that won't break the bank?
For the front I'm probably going to either cut a coil or 2 off the springs or get some drop spindles. Or both. |
02-18-2010, 10:48 PM | #2 |
Re: Lowering shackles?
Bell tech is the way I went, no problems.
Chris
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
02-18-2010, 11:03 PM | #3 |
GM Addicted
i just put some in my truck recently, i ordered them through summit. They are the summit brand ones, but there just repackaged ground force drop shackles, they were 50 bucks if i remember correctly. The shackles are good for the price and if you didn't know you have to notch out the under side of the bed so they clear it comes with all the measurements on where to make you cuts not hard at all.And cutting the coils i believe for every coil you cut its a 2 inch drop and dont cut half a coil either.
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
02-19-2010, 09:19 PM | #4 |
I know the pieces fit
I haven't heard that before. Why can't you cut half a coil?
Just curious, I'd planned on doing half a coil at a time (on my daughter's truck) until it looks right. |
02-19-2010, 10:33 PM | #6 | |
CHEVY ONLY |
02-19-2010, 10:47 PM | #7 |
Cool. I thought I'd stumbled on some voodoo I hadn't met before. And the belltech/oreilley's tip is excellent - my daughter is ready to tear into her truck.
02-20-2010, 10:44 AM | #8 | |
yeller
Misinformation gets under my skin. I too listened to advice on a message board AND the instructions when I put on my drop shackles back in the 90's...notched my bed supports to clear the drop shackles, turned out I didn't have to because I have the longer 56" springs. That still bugs me...now I have a notched supports for no reason at all.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 02-20-2010 at 10:45 AM. |
02-18-2010, 11:05 PM | #9 |
Thanks for the info guys.
02-18-2010, 11:14 PM | #10 |
also if your not wanting to order the shackles,i just picked some up at an o'reillys
there belltech shackles for our trucks and they were only 40 bucks |
02-19-2010, 01:57 AM | #11 |
Wow, definitely gonna ride by there and check 'em out.
02-19-2010, 02:07 AM | #12 |
GM Addicted
be carefull though i kno autozone sells some cheap brand ones, id order the summit ones
02-19-2010, 02:24 AM | #13 |
If someone local has belltech's then I'll buy them since I've heard good things about them. But I won't buy any cheapos.
02-19-2010, 08:13 PM | #14 |
6.0 powered square
oreilly auto parts sells beltec shackles, also you cold remove a leaf or two lower it more
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
02-19-2010, 09:25 PM | #15 |
GM Addicted
My grandpa and dad have always said that ill tell him to fill in on this question, if i remember right it sags or something like that will tell him to answer this question for you..
02-19-2010, 11:09 PM | #16 |
GM Addicted
i heard that if you cut 1/2 it doesnt sit in the arm bucket right idk just what ive heard
02-19-2010, 11:20 PM | #18 |
GM Addicted
yea true just saying what ive heard
02-19-2010, 11:22 PM | #19 |
Happy to be here
You can cut a 1/2 coil on the springs with no problem. Just make sure the coil is seated properly in the spring pocket. The most important thing about cuttings coils is to avoid excessive heat. This will lead to sagging springs.
02-20-2010, 12:34 AM | #20 |
I'd planned to use my angle grinder, no torch. I think we'll be good, I just wanted to be sure since I'm somewhat new to lowering and this is my daughters truck. Thanks.
02-20-2010, 01:31 AM | #21 | |
Same here, I don't have a torch so angle grinder or possibly my chop saw. |
02-20-2010, 10:17 AM | #23 |
02-20-2010, 12:09 PM | #24 |
The forum seems to be over-run lately with mis-information and "I have heard" posts....it is to a point where I'm plain tired of correcting all the bad info.
I dunno what can be done about it though.......
CHEVY ONLY Last edited by joe231; 02-20-2010 at 12:10 PM. |
02-20-2010, 08:03 PM | #25 |
GM Addicted
my bad **** was just putting what i thought. Not saying i know everything just saying from experience. Thought the whole idea of this website was to help others out, but i guess you have to be a ****in expert to post anything now huh.....
