Old 02-19-2010, 07:58 PM   #1
kenm78
Broken Down
kenm78's Avatar
Brake question
Ok I just got a 82 Chevy 4x4 a couple weeks ago. I noticed while medium to hard braking it pulled to the right so I had to counter steer to the left. I pulled the tires and inspected the brakes the right side inner pad was marginal compared to the outside on that caliper. I decieded to do a brake job. I replaced both front calipers $14 each can't beat that right? Wagner Thermoquite pads I had the rotors turned. I also replaced the inner and outer bearings on both sides. I bleed the brakes etc. It stops better, but it still pulls to the right??? I'm at a loss here. I do notice that if I brake really hard the back tires lock up a little. Any ideas or suggestions to check. The way the caliper floating pins looked I figured that was the reason I was getting the pull. I guess not.....
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 02-19-2010, 08:04 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Brake question
rubber lines
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-19-2010, 08:11 PM   #3
kenm78
Broken Down
kenm78's Avatar
Re: Brake question
I was thinking that but didn't want to throw money at a problem and it not work. I will get some and see if it fixes my issues. Thanks.
kenm78
1982 Chevy 4X4
Project truck
Old 02-19-2010, 08:14 PM   #4
old Rusty C10
Re: Brake question
other thing id do is flush the lines out real good i shoulda said that along with rubber lines
Im assuming that you checked the air pressure and tire sizes to make sure both are correct
Bob
I hate cancer!!
Old 02-19-2010, 08:18 PM   #5
3r!c84
Badass
3r!c84's Avatar
Re: Brake question
check the back drums to,you might have a axle seal leaking and there is gear oil on that drum(in-turn not letting the brake work on that side) so there could be a pull there
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-19-2010, 08:25 PM   #6
kenm78
Broken Down
kenm78's Avatar
Re: Brake question
Thank you both!!!
kenm78
1982 Chevy 4X4
Project truck
Old 02-19-2010, 11:19 PM   #7
Oldschool82
Balls to the wall!
Oldschool82's Avatar
Re: Brake question
Just went threw the exact same things with my 82 1/2ton. I did not replace any lines like the others mentioned, but replaced the hardware (drums,shoes,springs and wheel cylinders). brakes are doing fine now and that right rear has not locked up on me any more.
Oldschool82 is offline   Reply With Quote
Old 02-19-2010, 11:25 PM   #8
3r!c84
Badass
3r!c84's Avatar
Re: Brake question
spray the right rear brake(inside the drum) with brake clean and i bet you it will lock up,then that means you got gear oil in there so its letting it slip.
ask me how i know this?
i have the same problem
-00 Saturn 5spd
1/4:13:90
Old 02-19-2010, 11:48 PM   #9
Oldschool82
Balls to the wall!
Re: Brake question
Not disputing your ideas...just telling the guy what just worked for me on my truck. I will say that I have not heard of a brake locking up due to being sprayed with brake cleaner.
Old 02-19-2010, 11:50 PM   #10
3r!c84
Badass
3r!c84's Avatar
Re: Brake question
i get what u mean...and not just spraying brake clean will make it lock up i mean..to clean off all the gearoil that has leaked onto the shoes and the drum.
-00 Saturn 5spd
1/4:13:90
