02-20-2010, 01:25 PM | #1 |
Between Trucks...
Rebuilding Door Hinges
I need to rebuild my drivers side door hinges. Can I just pull the door and do it on the truck, or is it possible to get the hinges off with out pulling the fender? Looks tight there. I'd prefer to do it on the truck, just to make rehanging the door easier.
Beat it to fit, Paint it to match... |
02-20-2010, 01:37 PM | #2 |
Re: Rebuilding Door Hinges
i dont think u can get them off, but once u do its easy i just bought the kit from inpala bobs for the lower and a new upper they work great.
02-20-2010, 01:46 PM | #3 |
Between Trucks...
Thanks for the input. I'm going to try pulling the door and doing them on the truck.
02-20-2010, 02:22 PM | #4 |
Has more rust than truck...
I just did my drivers side. I think the only thing that might stop you from doing them on the truck is the amount of force it took me to get the old pins out. I had a BFH and my vise and had to work the top pin back in and out to get it out. Good luck
02-20-2010, 02:28 PM | #5 |
Between Trucks...
Hmmm. Is your truck apart? I don't have a problem with pulling the hinges, just don't want to have to pull the fender to get them off.
02-20-2010, 10:13 PM | #6 |
Ya, I had the whole front clip off. I also don't own a torch yet so pb blaster and BFH got the job done.
02-20-2010, 04:56 PM | #7 |
Watch out for your cornhole !
Clamp the hinge in your vise and use a torch to apply heat to the hinge around the pin area, not on the pin itself. Get them good and warm and the pin comes out every time.
02-20-2010, 05:27 PM | #8 |
Between Trucks...
O.K. sounds good. Uhh, am I going to be able to remove the hinges with the fender on?
02-20-2010, 06:35 PM | #9 |
Grand PooBaa Member
Hey Sin, you just cant get the answer you want about taking the fender off eh buddy. LOL
Im not sure my friend, but I use PB Blaster, it works better than WD-40 or rusted bolts. The torch will work also, just to heat things up. |
02-20-2010, 06:45 PM | #10 |
Between Trucks...
LOL, Hey Vince, how's it going? About time for another Board Meet.
02-20-2010, 07:41 PM | #11 |
Grand PooBaa Member
Hey Bro, your right, it is time for a meet. Im game, still working on the Cam Replacement, due to the rain have not had time. Will try to finish by the weekend coming up. Who wants to host?
02-20-2010, 10:36 PM | #12 |
You can do it with the fender on, but you can not rebuild the hinge on the truck, there is not enough room. You need to get a flex head 9/16 gear wrench and some patience to get at the bolts, but it is no big deal. Use a sharpie to mark the location of the hinges originally and after rebuilt bolt them back on. hope this helps, harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
10-21-2010, 09:53 AM | #13 |
True Addiction
Any ideas on how to pull the pins without a torch....? Thanks
RCC |
10-25-2010, 01:31 PM | #14 |
X2 on the propane torch. They are handy if you ever do any plumbing around the house but they can be REAL handy in the garage for getting nuts & bolts loose. Got one that self ignites & has the button to keep it on with just a push. Push button again to turn off quick. Not too expensive either.
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
10-21-2010, 10:03 AM | #15 |
Between Trucks...
Try an air hammer with a pointy chisel. I used a propane torch as well, but it might not be necessary. And as an update, I was able to rebuild the hinges on the truck.
Beat it to fit, Paint it to match... Last edited by Sinister; 10-21-2010 at 10:03 AM. |
10-22-2010, 10:49 AM | #16 |
Grand PooBaa Member
10-22-2010, 10:53 AM | #17 |
Between Trucks...
Hey Vince, doing pretty good. How have you been?
10-22-2010, 07:58 PM | #18 |
Grand PooBaa Member
I've been ok. Trying to enjoy my truck since the new engine got installed.
Also i want to drive it as much as I can, I got an offer, and I might have to take it. So playing when I can. I want to keep it, but,................ |
10-22-2010, 08:02 PM | #19 |
Between Trucks...
Hmmmm. You do what you gotta do. Take it easy.
10-25-2010, 12:37 PM | #20 |
Grand PooBaa Member
10-25-2010, 12:57 PM | #21 |
Between Trucks...
Yeah, it'd be a bummer to sell it after all the work you just put into it.
A Board meeting would be cool if it's not too far.
10-25-2010, 01:13 PM | #22 | |
Grand PooBaa Member
I figured it was time we came out your way. A few people are talking the IE. Heck it can be something as simple as meeting at a burger stand. More of a catching up meet. |
10-25-2010, 01:14 PM | #23 |
Between Trucks...
$7000? Yeah, I would have thought about that too.
10-25-2010, 01:21 PM | #24 |
Grand PooBaa Member
See I was not giving it away. LOL
